Results 1 to 25 of 33
Im Broken DowN on Ducati on mass pike
    Addict jbmass's Avatar
    Nov 2010
    Warwick, RI
    I'm right past the 95 tolls, heading toasted the city, if anyone can help me out gimme a ring!
    (617) 515-4494
    Just Registered Doc's Avatar
    Jericho, VT
    Re: Im Broken DowN on Ducati on mass pike
    What is wrong with the bike? Do you need trouble shooting help or physical help?
    Awww fuck. Been there. Well, not THERE. Same situation though. Wish I could do more than post a worthless reply...
    Good luck! Hopefully someone'll jump to the rescue soon enough!
    Nov 2010
    Warwick, RI
    It's an electrical issue, brand new bettery is sucked out of juice, I think the charging system isn't working
    Nov 2010
    Warwick, RI
    Anyone have a truck or trailer in the area?
    I sent Justin a text. I'm about an hour out, unless someone else available is closer.
    Oct 2004
    Southeastern Taxachusetts
    Quote Originally Posted by 07BladeRider View Post
    Get to getting him Chuck!
    MSF RiderCoach
    MSF Dirt Bike School Coach
    she rides like the wind
    & smells good too.
    Quote Originally Posted by jbmass View Post
    Quick check...
    Are your Batery connections tight?
    Nov 2010
    Warwick, RI
    Yep connections are tight
    Heading out now.
    Tucson, AZ
    Ok, I know no one ever thought this would happen...
    Way to step up Chuck.
    Original
    Lifer 03Worc9R's Avatar
    Worcester, MA
    I take it you already tried jumping it?
    I have my moments. He got the bike started, but I'm still heading out, just in case.
    Lifer LuvDog's Avatar
    Ashland, MA
    sound pretty darn familiar.
    2003 ZX7R
    1995 916
    Nov 2010
    Warwick, RI
    I made it a mile before it quite out again, weird. Oil's fine, fluids are fine, when it starts to sputter and die the signals and lights arent working. Battery isnt be recharged I think. Atleast I made it to another breakdown area.
    Junior Member keet2's Avatar
    Jun 2009
    sugar hill,NH
    i had a similar sounding problem with my 98 vfr..was a rectifier/regulator issue.....good luck with your diagnosis.....
    Posting Freak
    New Hampshire
    916/748 bad connection between the stator and regulator pretty common.
    Get the fairings off and and follow the wires out of the stator and look for a bad connection short etc.
    Worcester, MA
    Will give you $1000. for it as is.
    jk, hope you get things worked out.
    Tucson, AZ
    Maybe the band of gypsies in your engine decided that instead of making a dry clutch sound, they were going to get drunk and pass out.
    Original
    Just Registered drop's Avatar
    Bradford, MA
    i'm in kendall square with a pickup but i don't have ramps with me...
    - Jamie
    2009 K 1300 S
    Ashland, MA
    It's a very common problem with the 916. It happened to me on a group ride a while back.
    Check your R/R. Mine happened to be ok, but it's often the problem.
    The other main area to check is the wiring from the stator. Its prone to breakdown from heat. Switch to a higher gauge and possibly replace the connector if it looks melted.
    2003 ZX7R
    1995 916
    Nov 2010
    Warwick, RI
    Saved, Chuck rescued me and the bike, and the gypsy gremlins.
    Lifer DuncanMoto's Avatar
    Nice Chuck!
    Next time you can certainly save the ride and call me since you were only about 1 mile away from our shop.
    Hypertarded
    RI / CT border
    Heading out now.
    very cool
    JB good luck with the bike and Chuck you got some good karma coming your way
    Nov 2010
    Warwick, RI
    Bike's home, three cheers for Chuck! What a horrible place to break down!
  1. EZ-Pass didn't register on the Mass Pike... now what?
    By QuincyGixxer in forum General Bike Related
    Last Post: 04-26-11, 06:35 PM
  2. Auburn 146/Mass Pike Sunday Morning?
    By BusaBoy in forum Rides & Events
    Last Post: 05-29-07, 09:26 AM
