Ever since the loss of my bike
http://www.nestreetriders.com/forum/...er-boston.html
I've been looking at some dirt cheap bikes that need repair for a winter project.
Has anyone ever done a frame swap on a bike? How is it?
Every winter. Gets easier everytime. 1st time was a bitch.
Five hours tops.
special out of the ordinary tools needed?
how about the front forks and the swingarm? any special alignment needed?
Yeah, not particularly difficult but will take ya a while first time around. Setup the bike in a place where you know you can leave it for a long while. For the ones I've done, I've left the motor blocked and lift the frame off the motor. Can help to either have a buddy or a engine lift, depending on how tricky it is to lift off.
Highly recommend getting your hands on a factory service manual. Other than that, if you are good w/ a wrench its not a huge deal.
Usually only small # (2-4) of specialized nuts depending on the bike. The steering stem requires a adj. pin spanner or toothed socket, and usually the swingarm and maybe a motor mount or two will also require a toothed socket. All of which you can make w/ a dremmel like hessogood said. Here's an example: http://www.komotodraggin.com/engine_hayabusa.htm
Tag the routing for the wires/cables and label plug pairs. Label the bolt locations. Kinda common sense stuff.
Plan on doing other maintenance while pulling frame: check plugs, valve clearance, etc... Very easy w/ motor out.
U don't need the Special tool just take the bolt off and slide it out....2-3 hrs for a F4 motor swap
took me a couple days to swap everything over to a bare frame. this was on a race bike so no headlights ect.
MAKE SURE YOU MARK WHERE YOU'RE WIRING GOES
Its not that bad...marking your wiring is the most important (in my opinion)
I also had plastic cups marked with the contents, nuts and bolts to specific sections of the bike would have their own cup.
Once you are actually removing the engine its always easier to have an extra set of hands...you can use a floor jack though like I did.
..And be sure you have plenty of beer, you can run out pretty quick if this is your first time.
Chris
LRRS Expert #160
