Results 1 to 25 of 28
heat tape wrap pipes?
    May 2003
    Lakes Region, NH
    Yay or nay? No real rhyme or reason just kinda want to wrap em. My KLR pipe is showing some surface rust so I was thinking of wrapping it. Reading about it seems to add some performace but, lets be honest, I ride a KLR so performance....well, what performance.....
    + & - of doing it?
    Bras cause cancer.
    Lifer R1's Avatar
    Somewhere you dont know...
    Re: heat tape wrap pipes?
    I had it in the works for my r1 for temperature reasons.
    i say yay
    it also looks pissah!
    Meriden, Ct
    The wrap will trap moisture against the metal thus accelerating the rusting process...
    Lifer Pittenger5's Avatar
    Austin
    I did my KTM cause it kept setting my pants on fire. Its still hot, I dont notice performance, and its kind of ugly. But at least my pants arent getting set on fire.
    Zip Tie Alley #505
    Meriden, Ct
    So, you have successfully extinguished the fire in your pants?
    Austin
    Only until the next time you talk dirty to me.
    Zip Tie Alley #505
    Wirelessly posted (Instinct: Mozilla/4.1 (U; BREW 3.1.5; en-US; Teleca/Q05A/INT))
    The heat from the exhaust will evaporate the moisture. you could get a wheel for your drill and go over the rust and then paint it black with some grill paint
    Old and Slow Sheppo's Avatar
    Westford, Ma
    header wrap is best if you take it off at the end of the season and redo it every year. On the racecar it trashed a pair of headers until i started re-doing it every year. It does hold moisture over the winter.
    Posted by Jane in BoxChat
    Arlington MA 02474
    BBQ black spray can -- Rustoleum or Ace works great.
    I you do decide to wrap, you could take the overkill route:
    -- paint the pipe
    -- wrap the pipe
    -- paint the wrapped pipe.
    Maybe just paint is the way to go for the KLR.
    Dec 2005
    Near The Dragon
    here's the problem with wrap, it holds the heat in
    well duh, right?
    no. the headers themselves are able to dissipate a lot of heat to the air if they are left original. if you wrap them, the temperature that the header will experience is significantly higher, and as we all know, increased heat ruins any heat treatment and increases reactivity in chemical reactions (like rusting for instance).
    long and the short of it is that it typically will cause a rust/failure of the header fairly quickly.
    better option is ceramic coating, which is actually done both inside and out, which protects the pipe from the heat instead of forcing it to experience more of it.
    but both work.
    your money, your call.
    Get out while you can
    Find your own path
    May 2003
    Lakes Region, NH
    thanks guys - i was really looking to do it for looks cause i wasnt really plannin on gettin any performance gains...maybe i'll just spray it like everything else on the bike
    Bras cause cancer.
    I spray mine, works like a charm.
    Senior Member Brendin87's Avatar
    Sep 2011
    New York
    Instead of starting a new thread I figure I'll just use this one.
    I wanted to know if any of you track guys have done this? I did it on my R6 because the pipes are causing issues with the fairings. I also put a sheet of aluminum heat shield on the fairing.
    Lifer eboos's Avatar
    I had to do it on my Buell because the heat from the headers melted my cam position sensor.
    As far as cons for doing it, I stained a pair of jeans while wraping the header on my lap. It goes on wet and can be messy.
    I had my full exhaust done at one point. Started falling apart after a few years of abuse. I still have the mid pipe done because my boot is there.
    Just Registered Doc's Avatar
    Jericho, VT
    Hawks headers are done, definately keeps some heat away from those areas.
    Cons, if it gets wet and doesn't dry quickly it can corrode your pipes.
    Sep 2011
    New York
    I should probably include that I have stainless pipes.
    Member ecd2004's Avatar
    Apr 2010
    New Hartford/Colebrook, CT
    you mean the wire brush wheel? I've been meaning to paint my headers because theyre really surface rusted.
    Also, are header gaskets crush gaskets? do they need to be replaced every time the header is removed?
    Sep 2011
    New York
    The gaskets are a copper ring. I don't replace them everytime
    TWINS! xrocket21's Avatar
    Central Maine
    I use it on my sti, and I plan to do the ATK so I stop burning my leg
    Before, stainless headers:
    wrapped
    coated in black silicone header wrap spray
    On a side note: the heat wrap also comes in REAL handy if your woodstove uses little strips of similar material to line the clips of your door that hold your glass...
    New England Stove Riders?
    rrrright down by da beach island boyeee's Avatar
    Quincy, MA
    you aren't going to get a better how-to or pros/cons than here: http://forums.nasioc.com/forums/show....php?t=2303664
    he uses a new kind of wrap that doesn't require soaking it to install. just wrap it on and you're done. I'm going to use this on my car as well as the mid-pipe on my Triumph
    Why Lie? It Was Me.... HO-HUM-R1's Avatar
    Aug 2011
    North Shore Ma
    I did the stock exhaust on my r1 and i thought it looked great. They have the black wrap at pepboys. Also if you use the black silicone sealer like you are supposed to, then moisture isnt an issue at all because water won't soak in and when was the last time you saw condensation on your exhaust pipes?
    Go for it and don't look back... it looks and works awesome and the negative stuff being brought up is either a different application or myth.
    2006 Yamaha R1, Graves Full Exhaust, BST Carbon Fiber Wheels, K&N Air Filter, EGR Blockoffs, Factory Pro Velocity Stacks, Power Commander 5, Stealth 520 Conversion -1/+1, FP levers, Ohlins shock, Ohlins fg327 forks, Ohlins steering damper, Sato racing rearsets, Goodridge SS shadow brakelines, EBC Extreme pads, Braking SK wave rotors F&R. few other appearance mods.
    Lifer markbvt's Avatar
    Georgia, VT
    I wrapped the pipes on my Bonneville; looks good on that bike since it's set up as a cafe racer. But it also had a practical benefit: when I removed the Secondary Air Injection system (which injects fresh air into the exhaust to combust any unburned fuel; this has the effect of heating up the headers and by extension the cylinder head), I found that when riding at 60-65mph or so in fifth gear, ie, low revs, high airflow, in cool temps, the bike had a tendency to stumble as if it needed some choke. Which, in effect, it did, because it was being overcooled. The header wrap helped keep the exhaust temp up, and the stumbling went away.
    --mark
  1. For Sale - Motorcycles | 2003 Vulcan 1600, black, 12K miles, Vance and Hines pipes (stock pipes also included)
    By juha_teuvonnen in forum For Sale
    Last Post: 12-09-17, 09:46 AM
  2. Suggestions on Exhaust wrap and Heat Shield Cloth
    By tsorfas in forum General Bike Related
    Last Post: 04-10-15, 01:37 PM
  3. Heat gun for vinyl wrap - recommendations?
    By Ductard in forum Pit Area
    Last Post: 03-23-15, 03:44 PM
  4. Wrap pipes ?
    Last Post: 12-06-08, 01:45 PM
