Results 1 to 16 of 16
HELP!!!!
    Apr 2012
    HELP!!!!
    I am going on a 4 day trip tomorrow. Came out to my griso and somehow the fitting for the fuel line that goes into the injector is broken.
    Anyone know of a quick fix?
    Apr 2012
    Re: HELP!!!!
    Re: HELP!!!!
    I don't see how. EFI fuel injection runs at pretty high pressures.. I wouldn't want to risk a JB Weld or similar repair in case it failed and you burst into flames
    I broke one of the 998's fuel hose fittings. Even at idle it could spray fuel a good 2-3 feet through the air.
    Apr 2012
    Re: HELP!!!!
    Yeah….that is what I was afraid of.
    Anyone have a moto guzzi griso they could lend me a part off???
    Re: HELP!!!!
    Quote Originally Posted by Jewcati View Post
    I have an extra bike you can use.
    Worst case.
    Just keep the rubber side down.
    Your park avenue leads to..
    holland ma.
    Re: HELP!!!!
    You need to replace the whole line sadly. The pressure is too great to be able to patch safely.
    Apr 2012
    Re: HELP!!!!
    Worst case.
    Very generous of you man. I’ll get back to you. I just found one on rider-share and submitted.…total ripoff.
    Thanks a million!
    Re: HELP!!!!
    Thanks a million!
    Most likely the bike available would be this
    HELP!!!!-3129065c-d1d9-40f4-9558-b8806e9b52e0
    If on the off chance my wife decides to ride herself to Laconia on her Rebel 500, on a permit, then this will be available:
    HELP!!!!-85ef02f3-57f8-4493-a7bf-7f0913114771
    Located in southern NH
    Last edited by OreoGaborio; 06-10-22 at 08:18 AM. Reason: just helping with formatting
    Oct 2020
    Chelmsford, MA
    Re: HELP!!!!
    Why can't you replace the fuel line?
    Re: HELP!!!!
    I’m sorry, I don’t have chaps available to go with the harley
    Re: HELP!!!!
    Cuz it’s Italian and you need specific olive oil to lube the fittings.
    Duh.
    Re: HELP!!!!
    Call Sanel/NAPA. They may have fittings to repair the ends. If all else fails, barb fittings and hose clamps. FI runs in the 60 to 80ish psi range
    Re: HELP!!!!
    It's not the line that failed, it's the fitting that broke off. The line is intact and holding onto the busted end of the fitting.
    Oct 2020
    Chelmsford, MA
    Re: HELP!!!!
    the only thing that might hold is JB. tack with super-glue the ends and then glob over the crack
    Re: HELP!!!!
    shit, that sucks man! hope you get it sorted, 4 days sounds fuun btw, you need to go electric gas is bustin' ur ass lately
    Re: HELP!!!!
    That fitting is broken. Don’t JB Weld or epoxy or anything, it’s not repairable. As bergs said, you can try a male-male barbed fitting with hose clamps if you can get the right size, don’t know if it will deliver the same amount of fuel though.
