ordered my hid setup but having a problem. the are both 55w one is an h9 and one is an h11 both ballasts will work with the h9 bulb but not with the h11. im thinking because of this i may of just gotten a bad bulb. but since im not familiar with hids could it be something else?
so... the only thing you change is the bulb right? you don't switch the power wires or anything? if so then it sounds like a bad bulb.
how do your lights work? both on all the time? or is one the low beam and one the high? could be that there is not enough juice in the system to fire the second bulb, but not likely.
Wirelessly posted (Tilt: Opera/9.80 (Windows Mobile; WCE; Opera Mobi/WMD-50433; U; en) Presto/2.4.13 Version/10.00)
so the h11 wont work with either ballast? bad bulb it is. If they are both the same wattage, the h# has nothing to do with it, just different physical layout of the bulb.
Just my .02
got it figured out. for whatever reason with my bike the plug can only go one way. the wires need to be swapped did that and plugged it in now it works.
bascially the plug in this pic needed to be swapped from where the red one is and black to the other side.
so much for plug and play eh?
my hardest part was hiding 3 ballasts lol
