Results 1 to 2 of 2
Shock is toast
    Pepperell, MA
    Shock is toast
    Tech info needed??
    I hit a large pot hole accidently Saturday & went airborn and bottomed out the rear shock, now the rear shock is leaking it's oil out. Can these be rebuilt & sealed??
    Or should I just use this as an excuse to upgrade to a better rear shock??? Any suggestions or what New Shock to get?
    www.tailofthedragon.com
    Member lee955i's Avatar
    Sep 2002
    Winter Haven, FL.
    Shock is toast
    What were you on? The RC shock can be re-done but not sure about the Yammie. As far as replacements, the Penske's are a really nice unit and will cost ya around 7-7 1/2 bills. There's always Ohlins but they're a little more money (generally, not much, though) but their stock setup seems to be a little stiffer for the road than the Penske, therefore not quite as comfortable.
    Check out Race-tech's site, Lindemann Engineering, or Dan Kyle, Traxxion Dynamics, and see their prices and services, then choose you're poison.
    Also, if you do decide to rebuild you're stocker, it'd be a waste to not get it re-valved and re-sprung for your weight
    Cheers, Lee S.
    I know i'm slow, you don't have to rub it in.
    Why, Yes! I do think you're a Wanker!
