Results 1 to 25 of 50
oil filter too tight
    Member scr1be's Avatar
    Feb 2010
    boston
    anybody ever have an oil filter that would just NOT come out?
    i tried to do an oil change for the first time on my bike.
    got a socket for the oil filter and tried to ratchet it out but it wouldn't go.
    i was afraid i'd tweak the actual housing.
    no idea what to do. i already drained the oil and couldn't do anything but add my new oil and left the old oil filter on
    grr now i guess i have to go to the dealer and have them figure out how to take it off. i think the previous owner tightened the shit out of it instead of hand tightening it. i wanted to use an oil filter wrench but couldn't because on the cbr600rr 2007 there's a coolant tank and some other engine piece right next to it so the wrench doesn't fit.
    so, what do you guys think? just go to a dealer? somebody suggested hammering a screwdriver through it but there's hardly room for that too.
    im' guessing i have to take it to the dealer, have them take off the filter, and then fill it up with new oil again.
    Lifer TIMMYDUCK's Avatar
    Feb 2003
    The 14th State Vermont
    Re: oil filter too tight
    Take appropriate sized phillips head screw driver and BFH and puncture it thru top 3rd of the filter.
    Drive it thru both sides and twist problem solved.
    TIMMYDUCK
    I've had that happen, mostly with the first oil change on a new bike. The screw driver trick is messy and doesn't always work. I've learned that breaking the oil filter free on a cold engine (hadn't run since the night before type cold) is MUCH easier than a hot engine, so before I even start my bike to bring it up to temp, I crack the oil filter and snug it back.
    Lifer slammp's Avatar
    Jul 2008
    Massachusetts
    No the screwdriver is the way to go. Ive had to do that a few times - its messy but youll get it just take you time you nay have to punch a couple holes to get a good grip just be patient.
    Oct 2005
    Wrentham MA
    What bike is it?
    On Ducati's you must warm the motor and oil first
    Graham
    Aka @DrDesmo TomBrady's Avatar
    Dec 2009
    LoDo Denver
    I would strongly recommend picking up a 16" pair of Channel Locks ... They'll spin off anything without a lot of muss, fuss, or puncturing the filter. $22 @ lowe's / HD
    http://www.toolup.com/channel-lock/460.html
    "In the end, it is not about the 'hardware,' it is about the 'software.' Amateurs talk about hardware, or equipment, and professionals talk about software, or training and mental readiness."
    '95 916 - '00 MILLE - '01 FALCO - '02 XX - '04 RSV-R 1060 - '04 S4R
    Get a honda car oil filter wrench and it will come off no problem...I have one that use all the time......pm me if u want to try it... Punch a hole can rip them then ur really screwed
    Lifer Stromper's Avatar
    Eastern Ct
    :iws:
    If you can grab the reinforce ring next to the motor
    I have 2 types that grab as you apply torque
    When you put on the new one oil the rubber and the at least 3/4 turn passed contact
    who knows
    I had to use these on my firs oil change.
    Quote Originally Posted by TomBrady View Post
    Derry NH
    Depending on how much room is around the filter and it's location, you could do the screwdriver thing. If it's anything like my R6, there is almost no clearance on the sides except for a small space at the bottom. If you can get straight on to the end, you can use the biggest flathead srcrewdriver you can find and hammer it in there, then crank on it with some pliers.
    beige camry attack mojobreakfast's Avatar
    Salem, MA
    I take a standard, cheap-o universal oil filter wrench like the one above, and I have a band of thick, knobbied rubber that I wrap around the oil filter first. I forget where the rubber came from but it's some kind of building material I had left over. This will remove even the most satanic of stuck oil filters. The rubber grips the filter and keeps it from slipping. Of course these wrenches will not usually fit in recessed areas. Works great on my own 08 Honda CBR tho. The factory filter was pretty well wrenched on there and I popped it off in 1 second with this method.
    no bikes currently
    I have the metal "caps" that go over the filter. They grip the entire filter from the outside edges and then you put a wrench on the cap.
    They work great.
    Also, it's not quite true to only put a filter on hand tight. There is an actual torque setting.
    However, this is a great reason to use a hose clamp on the filter. Costs $2 and takes 2 minutes... and then you can tighten the filter just enough and not have to worry about it loosening.
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    Wirelessly posted (BlackBerry Giggity: BlackBerry8330/4.5.0.186 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/104)
    If you have an R6, go with what Tony said.
    If you have your filter in front of the radiator, you may not get enough clearance if you have aftermarket headers.
    Posting Freak khuygie88's Avatar
    Dec 2009
    RI/VT
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Quote Originally Posted by DBKromz View Post
    what the hell bike has an oil filter in front of the radiator? I honestly thought you were better than that, guess you proved me wrong
    Feb 2010
    boston
    the problem is it's a 2007 honda cbr600rr. the filter is between 2 other things so i don't have a "direct" line of sight to it.
    so the only way was to get one of those "sockets" that cup the oil filter and then attach a ratchet to the end of that.
    even though i did that it was too tight. there's really no clearance for all of those other tools.
    and in front of the oil filter is my headers.
    i think my only choice is to put the socket-cup thingy over the filter and find a LONG ratchet wrench for more leverage.
    Quote Originally Posted by scr1be View Post
    Nope...you have a spare pair of handlebars? I use those on the end of my wrench all the time. That or a section of pipe.
    Lifer joeswamp's Avatar
    Sep 2006
    Swampscott, MA
    Or you could just spring for a breaker bar, which is what you're supposed to use anyway for breaking free really tight stuff -- much less likely to suddenly let go if you apply too much torque. Comes with a longer handle than a ratchet, and you can also slip a pipe over it (although you're not supposed to).
    Joe
    04 Thruxton (Street)
    01 SV650 (Track)
    Quote Originally Posted by joeswamp View Post
    Just like I'm supposed to follow the speed limit on the street too right?
    Sep 2006
    Swampscott, MA
    Very good analogy
    Joe
    01 SV650 (Track)
    Salem, MA
    I have an 08 CBR600RR, so same as yours. The oil filter location is a little tight but really not that bad. As I mentioned, my factory filter was on there like a mofo. But with the cheesy universal filter wrench and a chunk of rubber to keep it from slipping, it WILL pop right off. Don't be afraid to put some back into it... you gotta give it a quick downward wrench, stand above the wrench and push it down real quick with your weight... the sucker will come off. Although it sounds like your previous owner probably put a filter on without lubing the gasket...
    no bikes currently
    like my bike, aftermarket headers decreased the space to the filter. but if the bike is an R6, the oil filter is in a totally different location.
    Bridgewater, MA
    you sure its not behind the radiator?
    Lifer Currently's Avatar
    Ooltewah, TN
    Right company ... Channel lock but wrong tool.
    They are called oil filter pliers and the brand I have is made by KD Tools.
    You will use them over and over again meaning it is a good tool to buy.
    Never had it fail to remove an oil filter yet.
    Mine looks like the one below ....
    If loud pipes save lives, imagine what learning to ride would do.
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    +1 on the filter pliers, they're awesome.
    As far as the "cup" thing to go over the filter and use a ratchet with... if you're talking about what I think you are, they're really only good for putting the filter on, not taking it off. Its a used oil filter... doesn't matter if you F the thing up in the process.
  1. K&N X-Treme Motocross air filter vs. Foam filter?
    By Ductard in forum General Bike Related
    Last Post: 07-14-15, 01:05 PM
  2. Getting tight...
    By markbvt in forum Vermont Events
    Last Post: 05-26-10, 07:35 PM
  3. Tight 10 or Not?
    By senecak19 in forum Pit Area
    Last Post: 09-15-06, 05:18 PM
  4. tight T10
    By SVRACER01 in forum Pit Area
    Last Post: 08-16-06, 05:42 PM
