Results 1 to 18 of 18
ZX9 help
    Member iwannaride's Avatar
    Feb 2005
    Methuen, Ma
    ZX9 help
    I have been having trouble with my 2002 zx9. When driving the bike in second gear around 40mph if you try to speed up it starts bucking. I had all the carbs recleaned, replace all fuel/vacuum lines, Fuel filter, fuel pump, fresh gas and new spark plugs. I have been told that it sounds like an electrical problem so i checked all spark and it all seems fine. All the plugs seem to look the same. they are the same shade of brown. I am running out of options and the dealer says that i should change all coil boot and computer. That is around $700-$800. I am in desperate need before i bury the zx9.
    thanks for any input
    Member Zero's Avatar
    Nov 2002
    Attleboro, MA
    ZX9 help
    If it only happpens in second gear it sounds like your second gear could be going. Usually the forks get bent and/or the engagement dogs get rounded.
    ZX9 help
    i subscribe to the theory of:
    "Hey Doc, it hurts when I go like *this, what should I Do?"
    "Don't go like *this"
    ... just don't go like that
    Lifer Karaya One's Avatar
    Springfield, Mass
    ZX9 help
    It sounds like second gear is toast. Having owned several early FZR1000's, you get very familiar with what a bad tranny acts like.
    Does it do it in third or fourth gear roll-ons?
    Check out my eBay store!
    Dave - Motorace - Michelin
    Feb 2005
    Methuen, Ma
    zx9 help
    It does it in every gear. No matter what. I took out aall of the jets today and check to make sure they were all intact and ok. I blew out all of carbs and tried setting the air fuel screw at 1.25 turns out, 1.5 turns out and 2 turns out and it still does the same.
    Winchester, MA
    ZX9 help
    Check the ram air intakes. After I crashed my ZX6 I spent 2 months trying to diagnose a similar problem, ripping the whole fuel system apart. Turned out a moth had made a nest in my left ram air tube while the bike had been sitting.
    I hate moths.
    Feb 2005
    Methuen, Ma
    zx9 help
    I have completely torn every vacuum, fuel, air and any other type of hose off the bike and throughly cleaned them out. I don't think there is any dirt anywhere.. I am going to blow it up soon
    thanks for the info
    Winchester, MA
    Re: zx9 help
    Well now don't do that, even a broken bike's worth something to somebody. Hell I'd buy it if the price was right, I love a challenge
    Good luck with it, I'll post up if I can think of anything else, sounds like you've hit the usual suspects tho....
    ultrabuddy twrayinma's Avatar
    Apr 2002
    albukoikee
    Re: Re: zx9 help
    just what you need, another mechanic's project.
    here's a challenge for ya, keep track of ALL screws next time you do summat to the bike.
    Winchester, MA
    Re: Re: Re: zx9 help
    Bite me, gimp
    It's not "missing screws", they're "speed holes". Power to weight, you know?
    May 2005
    Bernardston, MA
    Re: Re: Re: Re: zx9 help
    Bite me, gimp
    When working on automobiles/mechanics, my saying is "If you can put it back together with less pieces than came off it and it doesnt fall apart, you made it more efficient."
    Apr 2002
    albukoikee
    Bite me, gimp
    i don't wanna be hearing about yer "speed holes," buddy.
    sounds like a personal problem. try the free clinic.
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    ZX9 help
    Possivle bad coils, cap ends or wires.
    Friends stumbling Suzuk was
    high resistance of resister plug boots.
    It takes more voltage for a soark under load
    Any back firing ?
    Glen Beck is John the Baptist
    Springfield, Mass
    ZX9 help
    I would go electrical next if it does it in each gear.
    Coils, plug wires, etc.
    I'm Sorry, What? Jank's Avatar
    Apr 2002
    North Walpole, NH
    ZX9 help
    Did you check the float height?
    Chris J.
    Feb 2005
    Methuen, Ma
    zx9 help
    I checked float height. <My bike has the coil and boot as one. They are electronic. I tried one off of a friends zx9 but still nothing. I took a compression reading tonight and I came up with 185psi #1 cyl. 182psi #2 cyl. 185 #3cyl and 190 in #4cyl. all are approx guage is kinda old. Owners manual says 220psi. I check my friends and his was the same as mine.
    Posting Freak
    Oct 2004
    ZX9 help
    Wahts up kid, call me in the morning I have a zx9r king I can set You up with.
    thanks Shel
    978-851-5005
    Feb 2005
    Methuen, Ma
    zx9 help
    thanks, anything will help.
