Page 6 of 7 FirstFirst 1234567 LastLast
Results 126 to 150 of 163
Project: Grom 2.0
  1. #126
    Re: Project: Grom 2.0
    Absolutely not. I am not taking off that header again after the 4 evenings it took to get it to bolt up.
    ok, understand, my K-Pipe is the 2 manifold bolts and a hangar bolt and yer done, no fishing pipes or anything in the way
  2. #127
    after 3 evenings of frustration, i had to bend the brace a bit with a mallet to get the pipe to clear the frame
  3. #128
    New O2 sensor arrived today.
  4. #129
    And the new Hindle exhaust. This fit perfectly. Just need to make something to connect the hanger
  5. #130
    it starts but still having idle issues. it looks like there is air coming in at the throttle bodies. not sure if the TB's are bad or if the OEM clamp is worn. i'm borrowing someone's spare TB and getting some more silicon couplers to make sure everything is air tight
  6. #131
    TWINS! xrocket21's Avatar
    Central Maine
    no holes in it?
    Parts arrived yesterday.
    New K&N crankcase breather filter.
  8. #133
    New silicon coupler to replace the OEM clamp to the throttle bodies. This fixed my air leak issue!!!
  9. #134
    Now I have a proper 13.3 air fuel ratio after adjusting the idle back to 1600 - 1800 RPM and tweaking the fuel adjustments in aRacer.
  10. #135
    Trimmed the inner plastic fairing to fit around the radiator. Dremel arrived today, so it was perfect timing to check more items off the list
  11. #136
    Now that the bike runs, I can install the OEM bodywork and the aftermarket side fairings. Because this motor is wider, I won’t be able to use the middle lower vent to connect the two sides together. Might have to just use a zip tie.
  12. #137
    Front sprocket arrives today which is the final piece.
    I can install the chain and front sprocket today and ride it around the block.
    I’ll need to get a bracket made to connect the exhaust to the undertail. Currently using a zip tie just to hold it up for now.
    Then fresh tires and angled valve stems are already ready to go on the bike.
  13. #138
    Definitely going to need a video of a race start to once you’re all buttoned up
  14. #139
    Old and Slow Sheppo's Avatar
    Westford, Ma
    it doesn't look too complicated from the pictures. A piece of steel strapping, a vice with a BFH and a drill, your bracket will magically appear.
    Posted by Jane in BoxChat
  15. #140
    More fun:
    Sprocket arrived and tried to do the chain and sprocket.
    Ordered a rivet link, got a clip. Tried to install the clip and it broke in half.
    Put the lithium battery back on and it never charged. Reset button wasn’t enough juice to start it. Swapped the lead battery back on and the screw fell down the tail into the mess of wires I can’t get to.
    This bike is another day from going on the market and giving up.
  16. #141
    Chain and front sprocket done. Will need to wait for a rivet master link
  17. #142
    Exhaust hanger done
  18. #143
    Lithium battery from AntiGravity installed
  19. #144
    All put together.
    9 Not allowed! Not allowed!
  20. #145
    Central Maine
    Good looking bike!!!!
    Hypertarded
    RI / CT border
    Congrats, looks good, awesome work
    gonna be some surprised folks out on the road....
    holland ma.
    When is the first ride report?
    hopefully getting plates today, but it's raining.
  24. #149
    as a 125cc ? my k-pipe was already registered when I swapped motor, so officially I'm still 125cc
  25. #150
    Registered!!!
