Results 1 to 9 of 9
Ramps for the loading into the truck
    Just Registered
    Mar 2003
    Shrewsbury, MA
    Now that I have a pickup I've realized that I'm badly in need to a set of ramps.
    What is everyone using?
    I'm looking at the following options:
    http://www.discountramps.com/motorcycle-bike-ramp.htm
    Yes it's more expensive but it's 3 sections give me the option to have keep them hooked together and have a large stable platform or I can pull them apart and use them separately.
    option 2:
    http://www.lowes.com/pd_317085-287-R...=#BVRRWidgetID
    Werner 0.9-Ft x 7.5-Ft 1500-Lb Capacity Arched Folding Aluminum Loading Ramp
    definitely has the price point advantage.
    thoughts? opinions?
    Thanks
    Tim
    If you can't Race it or take it to bed, it's not worth having..
    Lifer JettaJayGLS's Avatar
    Tahoe City
    Re: Ramps for the loading into the truck
    Option one is awesome...they work very well and make loading bikes extremely easy and take the fear out of dropping the bike. Big issue is fitting them in the truck with your bike in there. you may think there is room, but even with just one bike in the middle, they take up a lot of space. With two bikes, they are nearly impossible to fit.
    Just Registered
    Mar 2003
    Shrewsbury, MA
    Very good call, I've borrowed one before that does not separate and it takes up WAY too much space.. To add more details I have an extended cab sliverado 1500. The ad does point out that the 3 sections cab be taken apart and stored separately in the bed or in the cab...
    Tahoe City
    Quote Originally Posted by Daytona440 View Post
    The ones I used could be separated. If you have a bike with full body work, it is a tough squeeze to get the wider middle section in there due to the wheel wells. Other issue was even if you get them on to fit flat on the bed, you will need to stack them at least two high and they will rub up against the lower part of the body work. This means you need to secure the stack very well against the side of the truck. Not saying it can't be done, I've done it, its just a lot of work you would not expect.
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    Goto your local shop and see what they got. Online kills local business. If the shop dosent have what you need....click away! And dont be shy to ask if they price match...
    Member jaehok's Avatar
    Autozone sells the piece that allows you to make your own ramps for 28 bucks. Just gotta get a 2 by 6 or 2 by 8 from the lumber yard. They come in pairs and I actually need only one so you can have one of mine for ten dollars! Let me know I'm located near by in Holden.
    Lifer Pittenger5's Avatar
    Austin
    Zip Tie Alley #505
    Secoast NH
    I have a double wide ramp like this : http://www.motorcycle-superstore.com...-ATV-Ramp.aspx
    That I am looking to sell.
    I like the double wide for confidence in on and offloading compared to single width.
    Tom
  1. Replies: 22
    Last Post: 04-16-13, 12:47 PM
  2. Motorcycle loading ramps
    By jeantarrou in forum General Bike Related
    Last Post: 01-23-12, 06:32 PM
  3. Motorcycle loading Ramps with Wheel chock $275
    By amato9588 in forum For Sale
    Last Post: 06-20-11, 12:19 PM
  4. loading bike w' 3 ramps?
    Last Post: 11-16-07, 08:45 PM
  5. Truck ramps for bike loading?
    By Honclfibr in forum General Bike Related
    Last Post: 02-02-05, 05:48 PM
