For Keith:
Niiiiiiice. What brand and what bike is it for?
Better be for the Hyper....
Q
That's quite a piston you have there.
--mark
you bumping compression?
13.0:1? 13.5?
You heat my balls bergsy![]()
Zip-Tie Alley Racing
LRRS/CCS #103
Chris - In the area of 13:1
saucy pistons like that would pull the studs right out of my block, i'm afraid. nice job, tricky.
Your missing 3!
Performance: 1397 JE bigbore, Dual Intake cams, Adjustable cam spockets, Sm air box mod,Pc3 usb,Ingnition box w/hub, and Lcd screen, Hindle stepped race header, Dual Fans, 24 volt starting
Suspension & Brakes: Ohlins road and track forks, Ohlins rear shock, Sprint top mount dampner, PRM top clamp, Dymag Carbon mags, Brembo HP rotors, Brembo Hp radial calipers,
Show & GO: Topgun undertail, Libertek led lights, Pazzo lever, PMR Switches & Kill,PMR cover. Revolution Custom Paint, Harris Grips.
I like how tricky Mike went to the trouble Of engraving them with his own special part # on the tops
Zip Tie Alley Racing #444
Signature edit by Tricky mike
Not to be a wet blanket, or maybe I am missing out on an inside joke, but wont an engraving on the top of the piston cause some localized hotspots (corners/edges), and some potential issues down the road?
Steve
Work Hard---Play Harder
...the butcher sharpens the tools of his trade....
Muhammad Ali.
don't pick on me cause I went to a trade school![]()
