Results 1 to 23 of 23
How should I sand this?
    Senior Member mell0's Avatar
    Manayunk, PA
    Hi all, so I recently lowsided my street triple, thankfully the frame sliders and my arrow titanium slider took most of the damage. I managed to clean all of the road grime and stuff off of the exhaust as good as I could. As of now I want to sand/polish out these scratches if possible. The dent in a way flows with the exhaust, so I don't think I'm going to replace it. Any suggestions on how I should tackle this? I believe it's titanium, and I want to give it a finish similar to the rest of the can, clean but not a mirror finish.
    Any suggestions as to sanding/ polishing techniques? What grit, what order, wet sand etc? I've never done this before so any insight would be awesome.
    Thanks,
    Andy
    Attached Thumbnails Attached Thumbnails How should I sand this?-img_0380-jpg   How should I sand this?-img_0376-jpg
    -Andy
    2013 Triumph Bonneville
    Manayunk, PA
    Re: How should I sand this?
    And I'm not sure why the pictures are upside-down, but you get the idea.
    -Andy
    Jan 2012
    Lowell
    Scotchbrite is what people in the car world use to polish scratches out of their titanium exhaust tips.
    I imagine scotchbrite and an hour or two would make that look a lot better...
    Jan 2012
    Lowell
    Upon some searching though some say that the titanium coating can't be polished, but at the state the exhaust is in now I'd give polishing a shot.
    Manayunk, PA
    I'm pretty sure I've seen polished titanium exhausts before. I think a scotchbright might work once I get some of the deep stuff smoothed out, but I'm thinking sandpaper might be my best first bet. Any suggestions?
    -Andy
    .... Manik's Avatar
    Ipswich, MA
    Im not exactly sure how to start, or what your best course of action is in terms of getting it to "like new condition", but if you are unable to do so, a sanding of the entire pipe followed by the aforementioned scotch bright will at least offer uniformity. Choose to do the sanding in a certain direction, down the pipe or around it consistently, and you may decide you like the effect while scotch brighting. A three hour restoration may turn into a 1 hour customization.
    09 Ex500- totalled
    08 SV650s!!!
    Cages: Ford Excursion
    Ford Mustang Gt
    Toyota Rav4
    Manayunk, PA
    Quote Originally Posted by Manik View Post
    I thought about that, but I think for now I'm just going to try to get the scratched surface to look uniform. Maybe if I get really confident in my sanding work, or know someone that could make it look good I'll have the whole thing done over, but for now I think I'm going to leave the rest of the pipe as is.
    -Andy
    .... Manik's Avatar
    Ipswich, MA
    I think that route is definitely best saved for a last resort. you can always sand it... un-sanding is a tougher trade.
    09 Ex500- totalled
    08 SV650s!!!
    Ford Mustang Gt
    Toyota Rav4
    Lifer DaveZX6r's Avatar
    NoChelmsford, Ma.
    Titanium is just like any other metal it can be sanded/ polished fine. No different than any other sanding process. Start coarse to get the deep stuff out then move down to finer grades. While your sanding it keep it wet with oil like even wd is fine. That will make it alot easier. Finish it up with scotchbrite if you please. If your unsure of what it will look like practice on the back side of the exhaust first. Just jump straight to the final grade or scotch Bruce or whatever.
    Senior Member hawk's Avatar
    Sep 2002
    Ma
    You can probably just buy a sleeve and replace it for short money. You really have nothing to loose. Have at it!!
    Steven
    Lifer SprintPoser's Avatar
    Apr 2002
    Central MA
    I would first look to see if you can get the replacement part. If not, it's just another metal but quite a bit tougher than most to polish.
    And you have a LONG way to go from the looks of the deeper scratches. I would probably use a flexible abrasive disc grinder to get the bulk of it done, or you'll be working on it for a month of Sundays. You only finish with ScotchBrite or BearTex woven abrasives to get the final lay. Start with 80 or 100 grit, then step up to 180, 240, 320, 400, 600, and then the woven to get that circumferential lay as the original.
    Bar keepers friend- get a moist towel and dab some of that on it. Rub it on the pipe and it will polish out... it worked for me. give it a try. You can get it at any grocery store for about $3.00
    Waterbury, VT
    The deep scratches are going to take a lot to get out. As mentioned before start with a course grit on a wheel (keep it moving). Maybe even a file to take down the really high stuff. I'd go the side of caution and start with 180 for the first swipe. It's a lot easier to go coarse because the finer sandpaper isn't working right. Look at polishing the entire can for the final swipe. I've had good luck getting a nice finish on aluminum using steel wool and WD-40 on the final pass.
    SSearchVT
    I would do...
    P80 just knock down the high spots
    P180 Get it a bit more down
    P320
    P600
    P1500
    P2000-P2500 Polished finish in the same direction as the previous was done
    Lifer 03Worc9R's Avatar
    Worcester, MA
    Cut the pipe up to the badge. Make a super short pipe. Done!
    Apr 2002
    Central MA
    Anything beyond 1200 is really going to polish it beyond the original finish. That original finish on the untouched part is clearly (to my trained eyes) done with ScotchBrite or BearTex type of woven abrasives, something in the 800 to 1200 grit range.
    The P2000 to P2500 is what I use to get plastic headlight lenses near perfectly clear. Only a hit from a P2500-P3000 range on a soft foam buffing pad gets them looking like they just popped out of the mold. One thing for sure is that Bar Keeper's Friend is only going to give the most handsomely-polished scratches. The worst of those are quite deep!
    Yea.....good thing i don't have any abrasives LOLOLOLZ
    Manayunk, PA
    Quote Originally Posted by DaveZX6r View Post
    Thanks
    Quote Originally Posted by hawk View Post
    Not sure on how the sleeve would work, the can is a weird conical shape.
    I think I may try by hand at first, but if it takes more than a day the abrasive disk sounds like a good second bet.
    Isn't aluminum extremely soft, and titanium extremely hard? You think the steel wool/WD-40 combo would work?
    I would do...
    P320
    P600
    P1500
    This may be my course of action, but with a scotchbright instead of the 2000 grit. Thanks.
    Quote Originally Posted by 03Worc9R View Post
    Not sure how that would work, given the odd conical shape of the exhaust.
    Thanks for the heads up!
    Buy a new one!
    Ha, if I had $800 floating around I sure would!
    -Andy
    Mar 2011
    TI is a bitch to polish. Ive tried it MANY times- it is nothing like polishing aluminum or stainless steel. This was with a high speed buffer too.
    Quote Originally Posted by Lxpony View Post
    i got a can of it for my car exhaust.
    Lifer Expat's Avatar
    Mar 2007
    Replace it with a carbon can....
    Check these guys out..
    http://pjengineering.co.uk/products.php?cat=5
    Apr 2002
    Central MA
    Titanium isn't hard, though it is a bit harder than aluminum. The characteristic that makes it such a PITA to polish is toughness. The Young's Modulus of titanium can be 60% higher than aluminum. The difference can be a LOT more or little less, depending upon the alloy. Just like any other metal, it's rarely found in a pure form. Oddly enough when you alloy the titanium with a little bit of aluminum, that is when it gets REALLY strong.
    With a selection of silicon carbide abrasives, it should clean up quick and look reasonably good again.
  1. For Sale - Gear | REV'IT sand 3 suit
    By Johnpewpew in forum For Sale
    Last Post: 10-14-18, 09:19 AM
  2. For Sale - Other | sand pail
    By cdovego in forum For Sale
    Last Post: 10-17-15, 11:44 AM
  3. Sand all over..
    By toocrazy2yoo in forum General Bike Related
    Last Post: 09-05-10, 06:54 PM
