Results 1 to 10 of 10
Service
    Lifer DaSarge's Avatar
    Oct 2002
    Cape Cod
    Service
    I Plan on putting my R6 in this weekend to get serviced, right now the bike has 15,000 miles and I was wondering what I should tell them to check out or get replaced. Any suggestions would be helpful. Thanks in advance.
    -Spence
    Service
    aw shit, thanks for reminding me i need my valve clearance checked
    Valves, Plugs, Oil, Coolant flush, chain & sprockets, ummmmm.... What year is it? carbs or injectors? a carb synch may be in order
    damn, where's my owners manual? There's a section that lists everything that should be checked & at what interval. and there's alot of stuff (mostly just little visual checks)
    Just Registered
    Is it not obvious?
    Service
    are we looking for waldo or somethin?
    www.gpsdiscussion.com
    motorcycleaddicts.org
    Service
    WHAT THE FUCK JUST HAPPENED?!?!?!?!? SEVEN RE-POSTS?????
    looks like i got some deleting to do... I got it, D
    Service
    Change the oil+filter and sync the carbs and you're done First valve check on the R6 is at 26k miles so don't bother
    I would say greese the wheel bearings but i'm sure every does that whenever they install new rubbers anyways so that should be all set as well
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    Re: Service
    -Spence
    trade it in for a kaw or zuk get rid of the yamajunk
    www.bostonmoto.com
    Forum Rules
    Dec 2003
    Ma
    Service
    if you ask them to check that, then according to them you're going to need, a valve adjustment, with expensive shims, new plugs, synthetic motorcycle oil, colant flush, new chain, set of sprockets, and ummm....a flux capacitor and new difribulator modules.
    May 2003
    Lakes Region, NH
    Service
    just rev it really high, kick her a few times and throw in water instead of coolant. that should take care of all your problems
    Bras cause cancer.
    Posting Freak Sidewinder's Avatar
    Nov 2004
    NH
    Service
    Spence do it all your self, Change the plugs, synch the carbs swap out the anitifreeze., like R7 said next wheel change lube the bearings.
    Thats all she needs...
    Bikeless
    Jul 2003
    dover, vt
    Service
    I swear I was expecting a dirty post... but apparently, we're just talking about DaSpence getting serviced.... my bad...
    GO TO TONY'S TRACK DAYS!
    I'm Bikeless.
  1. Do you do your own service?
    By jwm2k3 in forum General Bike Related
    Last Post: 06-27-13, 07:07 PM
  2. Hi again...14k service etc
    By getaddicted in forum General Bike Related
    Last Post: 09-21-08, 07:33 PM
  3. Lapinski Service Dyno Service Warrick RI
    By LapinskiService in forum General Bike Related
    Last Post: 03-06-06, 04:48 PM
