Results 1 to 16 of 16
steady throttle position but jerky response ?
    Posting Freak danny86's Avatar
    MA/NH
    At low RPM's ( basically under 40mph) when the throttle is steady the bike still jerks a lot. Its not smooth at all.
    I'm thinking its the map on the PCIII ?
    Its an 07 CBR1000RR
    Lifer SprintPoser's Avatar
    Apr 2002
    Central MA
    Re: steady throttle position but jerky response ?
    Possibly, but look to synchronizing the throttle bodies first.
    Raymond NH
    Pull in the clutch and make sure it's not undulations in the pavement.
    Lifer DaveZX6r's Avatar
    NoChelmsford, Ma.
    Have you checked your chains slack? Too much will do that too.
    Apr 2002
    Central MA
    With 740 posts and being here 3 years, I would assume the guy knows the difference between bad pavement, a loose chain, and a throttle that isn't responding well. I'd at least give him the benefit of the doubt.
    Degsy?
    Eh, Degsy just talks funny, doesn't make a bike do that. I would look elsewhere.
    TPS adjustment is my bet.
    Apr 2002
    Central MA
    Degsy knows those kind of bikes really well and is good at analyzing issues like that and fixing them. If he's not available or too far away, perhaps he can recommend someone else. Yes, it could well be the throttle position sensor, or perhaps a dirty fuel filter, clogged air filter, poorly adjusted valves, throttle bodies out of synch, any number of things.
    See also:
    http://www.nestreetriders.com/forum/...ine-cycle.html
    NoChelmsford, Ma.
    Degsy?
    Fair enough, however I disagree entirely with your assumption that a high post count equals bike knowledge. There are plenty of people on here with hight post counts that dont touch anything on their bikes.
    Also I can reccomend to check the easy stupid stuff alot more than saying take your bike to a dyno and spend hundreds of dollars getting it tuned which may not fix your problem.
    Apr 2002
    Central MA
    I did NOT suggest anything about spending big bucks on a dyno tune. No idea where you got that impression, so I'm sorry if I wasn't clear.
    NoChelmsford, Ma.
    And I'm sorry if my post came off assy. I don't have my acs in yet. And the dyno was a response to the op, because thats where the only info we have on possible symptoms came from.
    Quote Originally Posted by danny86 View Post
    Its an 07 CBR1000RR
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    Synch the TB's and get a custom map on the dyno. It will be sweet....
    Dec 2005
    Near The Dragon
    first thing i would do would be to throw some seafoam injector cleaner through it..
    and go beat on it for a tank of fuel
    Get out while you can
    Find your own path
    Raymond NH
    You've probably already checked this, but a very worn chain can cause the symptoms you describe. If the chain has uneven wear, some sections will be quite a bit longer for a given number of links than other sections. I had a Regina chain do that a couple of years ago and it felt just awful at low speeds, felt like surging.
    Dec 2005
    Near The Dragon
    Oh, btw.. if it happens around 5500 rpm, there's not a lot you can do about it. that is the transition from lower injectors to both banks of injectors.. they all do it, and there's no known fix (last I knew)
    Find your own path
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Quote Originally Posted by Cerberus View Post
    a good tune with a PCV or Bazzaz should fix it since they control both sets of injectors
    Posting Freak boloson's Avatar
    Oct 2007
    Did u try unplugging the pc and run it stock?
  1. Throttle Position Sensor
    By Jim in forum Bike Maintenance
    Last Post: 04-26-10, 01:36 PM
  2. In response to Uncle Snake's boo boo...
    By MotoFreak in forum General Bike Related
    Last Post: 07-21-08, 08:23 AM
  3. Cheap HP/throttle response improvement
    Last Post: 10-23-06, 02:56 PM
