Results 1 to 18 of 18
Steering damper $?
    Lifer oVTo's Avatar
    Jun 2003
    North of Boston
    Steering damper $?
    I'm thinking about getting a steering damper for my RC51 for the NJMP TTD.
    The Scotts and GPR look about the same at about the same price. I can find them at about $425. Does anyone know where I can find a better price? Or have a reason why one is better than the other?
    Thanks.
    DanG
    - Blaise Pascal
    Lifer virtualbong's Avatar
    Metrowest - MA
    Re: Steering damper $?
    Isn't the Scotts damper take a little more work to install?
    Lifer union's Avatar
    Blackstone, MA
    I know a lot of people that have the scotts on the RC and are happy with it.
    James
    Dublin, NH
    The Scotts needs to be welded to the frame, whereas something like a HyperPro is just bolt-on.
    That's all I know.
    2023 KTM 890 Adventure R
    Lifer oVTo's Avatar
    Jun 2003
    North of Boston
    That's all I know.
    The rotary damper needs to be welded? Are you sure? I haven't seen that mentioned anywhere, just that it's not as easy to install as the GPR.
    Thanks.
    DanG
    - Blaise Pascal
    Dublin, NH
    Quote Originally Posted by oVTo View Post
    Thanks.
    I just checked the website, it looks like they have mounting kits for certain bikes, your RC51 being one of them. Guess I was wrong
    Some bikes require the bar to be welded, like my Z1k.
    TWINS! xrocket21's Avatar
    Central Maine
    I have a scotts, and it doesnt need to be welded, and isnt hard to put on. You just need a GIANT socket for the steering nut. Can be installed in 5 or 10 minutes
    Lifer slammp's Avatar
    Jul 2008
    Massachusetts
    Scott's does not have to be welded. I have it on my RC51. I would recommend the scott's for the following reason. I had the GPR on my 636. When I sold the bike and tried to get a mounting kit for the rc, it required a new fairing stay because the GPR is too tall. The cost for the mounting kit was going to be as expensive as the GPR cost me in the first place. I bought the Scotts and it fits under the fairing stay. It works great (actually they both work great), but the scotts mounting kits are considerably less.
    As far as actual mounting goes its easy. There is a ring/bolt combo that replaces the bolt in the middle of your triple tree. That ring has a bump out on the bottom that lines up with the notch at the bottom center of your triple tree, it also has allen bolts going all the way around it. You screw down the replacement bolt over the ring (line up the notch) and then tighten the allen bolts so the ring does not spin. The stabilizer then mounts down onto the ring with two more allen bolts. Finally, there is a piece that mounts over the top of your gas tank where the existing two bolts are. The two pieces interlock with a pin and you are good to go. The whole process will take 1/2hr if you take your time and use the supplied threadlock to make everything nice and tight. Removal for repairs takes like 2 minutes. It really is a good unit.
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    I also have the Scotts on my RC51. Just buy that one you will be happy and wont have to wait for it. The GPR will be on back order, believe me. They will take your order and then email you that its backoredered for the mounting kit. Just get the Scotts. (only trying to save you time, Ive been to this movie before)
    Call this guy, hes an RC51 owner and has his own parts business and service. Very fast and most likely the cheapest around too! http://www.scottsms.com/ His name is Scott, but not related to the Scotts damper company.
    Good Luck!
    Mar 2004
    Lynn, MA
    Agreed, you either need a 22mm socket or a big adjustable crescent wrench. Easy to install, but be careful.
    who knows
    Question to you all with steering stabilizers... If you are just riding on the street, will i utilize it's benefit’s? i was thinking of getting one but i'm not sure, will it simply be a waste of money??
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    I don't have one on my street bike and its fine, but it scares the shit out of me being able to move the bars so freely (after racing with one for years). Its definitely something I would suggest, but its also not a huge deal if you don't have one. However if you're ever in a situation where it'll save your ass... the $400 you spent on the damper is much cheaper than the consequences.
    who knows
    thats good to know, from what I understand it helps stop steering wobble from say a really big MASSACHUSETTS pothole on the highway at 80? is this correct...
    Jul 2008
    Massachusetts
    That is correct. I have been in a few situations where the damper has saved my ass. It's definitely worth the money (Out by you, let's say your hummin' along at a good clip and hit a bunch of frost heaves....in by me, its definitely the potholes and uneven patches). I can say from experience it's a sound investment, you will notice a very big difference in handling for the better.
    Yea, cover all of the triple in the Blue tape and then you can use a crescent wrench and not mark it up...cause no matter how careful you are its going to get scratched....
    Old and Slow Sheppo's Avatar
    Westford, Ma
    +1 for blue painters tape
    Posted by Jane in BoxChat
    who knows
    Thanks for the advice guys, looks like I have another item on my list of things to get!
    Superhero F4Iguy's Avatar
    Vermont
    i started a thread back when i got it, but about a month ago i bought a scotts for my f4i. i love it. it has already helped a number of times. i don't know about the GPR but they say the scotts is basically infinately adjustable, with a high speed damping, low speed (on the fly) adjustment, and you can set the degrees of dampening, with 4 settings: 34º, 44º, 54º, or full 78º. check out morepowerracing.com cheapest i found, for $407 for the mounting hardware and dampener.
    What?
  1. WTB 98-01 R1 steering damper
    By mack0092 in forum Wanted
    Last Post: 02-11-11, 01:40 PM
  2. WTB Steering Damper 03 r6
    By Jenni in forum Wanted
    Last Post: 01-22-10, 09:25 AM
  3. STEERING DAMPER HELP...
    By GixerJockey in forum General Bike Related
    Last Post: 06-13-08, 01:00 PM
  4. 929 steering damper?
    By wingerdor in forum General Bike Related
    Last Post: 04-26-08, 04:56 AM
  5. steering damper
    By Qfactor in forum General Bike Related
    Last Post: 09-27-05, 01:55 PM
