Page 3 of 3 FirstFirst 123
Results 51 to 66 of 66
Suggestions for safety wire pliers?
  1. #51
    Lifer Ductard's Avatar
    Sep 2013
    South Boston, VA (not a typo)
    Re: Suggestions for safety wire pliers?
    Where are you all buying these tools for (the most) reasonable money?
    Milbar 25W Safety Wire Pliers
    I followed Pete's suggestion and got them off of Crawford tool. A couple of bucks more than the best Amazon price but coming from Atlanta vs. California they'll get here a little faster.
    Not sure what great service Pete got that he was referring to but I'm hoping there's no need for further interaction with them once the pliers show up.
    I got a set of used bluepoints for ~$28 off of ebay (blue point is the private label brand for snap-on).
    I'd sell them to somebody here for ~$25 (despite the custom "partial return spring"* modification I sunk about $0.25 and 5 minutes of time into) - I like you Bubba, so I'd give you first dibs if you're interested.
    Only reason I bought new ones was to take advantage of momentarily misplacing them to upgrade to reversible and auto-return milbars. They grip great and cut great.
    The catch is give me this weekend to try to locate them but I can bring them to NYST the following weekend or the Classic the weekend after.
    *They are not auto-return type pliers. I just put a spring inside the handle. Nothing was drilled / cut / damaged. The spring just doesn't have quite enough "umph" to snap it back for a full return.
    LRRS 919
  2. #52
    The 26W's I got had a minor issue with the reversing knob being a little fiddly, so I emailed them & got a super quick response letting me know that sometimes they need a little break-in, but they'd be more than happy to swap them out for no charge.
    I fiddled with them for a little bit & sure enough they smoothed right out. Flawless ever since.
  3. #53
    Posting Freak Gecko's Avatar
    Jul 2008
    Doubt it. The wave is so it holds them firmly without little micro nicks in the wire that the normal knurling can cause. It's a "cool kid"/super anal safety thing. Totally unnecessary in my opinion but I think it was once required by the FAA? Doesn't make any difference at all unless you're wiring 3 or more bolts together with the same wire.
    Agreed ... but I wouldn't say its a "cool kid" thing (esp. since I've never been cool). As Pete says, it holds the wires better and doesn't leave little teeth nicks in the wire. When wiring together a sequence of bolts, I've had wiring break where those little teeth nicks are . . . like the two pinch bolts and axle. My thinking . . . if your going to spend the $$$ for a good set anyway, why not spend the few extra $$$ to get what you want. But ymmv.
    Pete . . . I don't think these have the cushion throat.
    Only reason I bought new ones was to . . . upgrade to reversible and auto-return milbars.
    The reversible feature is something I've come to appreciate immensely . . . and the auto-return feature, well, that's just absolutely necessary for any safety wire pliers
    John
    CCS/LRRS Expert #69
    LRRS Rookie of the Year 2004
  4. #54
    Quote Originally Posted by Gecko View Post
    Ah okay. Well ya lucked out!
    Gonna try making your own cushion throat with some RTV? Almost did that on a pair of cheap-o pliers before I got my good ones.
    PS. You're cool in my book
  5. #55
    FWIW I found a lot of value in watching a bunch of videos on how to do it on Youtube. I found drilling the holes to be trickier than getting usable wire in place. There are some fixtures to help - I don't have them.
    I'm starting to safety wire more stuff on my tractor, stuff like a PTO bush cutter vibates like crazy and the nuts are hard to get to.
  6. #56
    Sep 2013
    This spec sheet suggests that they do, but then again, some of the online sellers' listings say the 26W is the "tiger wave." Keep us posted.
    http://www.stridetool.com/wp-content...1/7W-flyer.pdf
    Yeah....I decided to upgrade when I realized that I think this is why I sometimes have problems with the half-loop around the bolt head wanting to "jump" over the bolt head when it comes time to twist. Am I right?
    I got pretty good with mine that didn't have it actually. Pull, hit with palm of hand, pull.
    I agree that it's a really nice feature, but I wouldn't call it absolutely necessary.
    LRRS 919
  7. #57
    Jul 2008
    It seems I stand corrected ... an unexpected added bonus! WooWoo!!! ... now there's going to be man-wrestling in Center garages! Pete ... let's get ready to ruuuuuumble!
    The reversible feature is something I've come to appreciate immensely . . . .
    Correct ... and there are some other things too ... use your google-fu and youtube-fu as I did and enlightenment shall be yours. Some of the sh*t those aviation pro's do is crazy.
    I got pretty good with mine that didn't have it actually. Pull, hit with palm of hand, pull. I agree that it's a really nice feature, but I wouldn't call it absolutely necessary.
    To each his own ... I've done it in the past when borrowing a pair ... hey, beggars can't be choosers. For me, I wouldn't buy a pair without the auto-return feature.
    Oh, and I'm confident that putting all the quotes back together properly doesn't suggest I have any ocd issues ... honestly.
    John
    CCS/LRRS Expert #69
  8. #58
    I fixed his post for you, too.... not that it was bothering you or anything.
  9. #59
    Quote- "with improved, smooth opera"
    Sounds good to me!
  10. #60
    go faster cdovego's Avatar
    Weymouth
    No bs - I'm shocked you guys have gotten 60 posts on safety wire pliers.
    Central Mass Powersports #123
  11. #61
    We were only at 59 until you jumped in.
    Weymouth
    62
  13. #63
    Sep 2013
    ...after 564 posts on chainsaws, nothing phases me.
    I have no idea what those guys are talking about. Its always popping up in my feed and I think checking the # of posts just now is the first time I've clicked on it.
    ...don't tell me tho....its more fun not to know.
    (6 months later, needs a chainsaw, becomes a regular poster in chainsaw thread.)
    LRRS 919
  14. #64
    City slicker...
    'tard. Wait 'till you need a lawnmower.. er, I mean tractor.
    If my MLB-7W's are here in time for the Classic (thanks Pete )
    SO JEALOUS!
    Guys, John showed me these things last race weekend & they look sweet... if you wanna spend 118 bucks on a pair of safety wire pliers, do eeeeeeeeeeeet.
  1. Replies: 74
    Last Post: 07-30-16, 05:27 AM
  2. Safety Wire Pliers
    By Ray-Ray in forum Wanted
    Last Post: 04-13-11, 03:16 PM
  3. Safety Wire Pliers?
    By oVTo in forum Bike Maintenance
    Last Post: 05-22-09, 07:34 AM
  4. Anyone need Safety wire pliers?
    By Doc in forum Pit Area
    Last Post: 02-22-07, 02:39 PM
  5. Safety wire pliers on ebay
    By Degsy in forum Pit Area
    Last Post: 03-27-03, 09:05 PM
