Results 1 to 25 of 25
Supermoto practice friday
    Senior Member Dannyf's Avatar
    Middleboro, MA
    Esmra round 5 is being held at Boxshop Speedway, Parsonsfield, ME this weekend and will be hosting an open practice Friday. Just an FYI if anyone is interested. Practice is 50 bucks and runs from 2-6.
    "When there's a gap you either commit yourself as a professional racing driver that is designed to win races or you come second or you come third or come fifth, and I'm not designed to come third, fourth, or fifth. I race to win, and if you no longer go for a gap that exists, you're no longer a racing driver."
    Ayrton Senna
    Re: Supermoto practice friday
    I'm angry at myself for not knowing this existed until right now...
    Lifer eboos's Avatar
    It's a fun place.
    Wait, open practice Friday? First I heard of that. I can't get out of work unfortunately so I'll just have to drop the hammer first race Saturday.
    Too small for a big bike? Tell me more....
    It'd be VERY tight, I know they've horsed around on 250s before though. I'm running GP80 and Open Pitbike.
    Blatant copy/paste:
    Quote Originally Posted by NEMM Rules
    Rules - Classes
    Premier Mini-Moto: A or B level rider on single cylinder machines with a maximum displacement of 110cc (2-stroke) or up to198cc (4-stroke), otherwise unlimited modifications, with the exception that they must maintain a mini chassis. Maximum wheel diameter, 19" front, 17" rear. Minimum wheel diameter 16" front, 14" back. Minimum age 12. The only exception is that riders under 12 may enter with 5 years or more of racing experience.
    Air Cooled: A, B, or C level rider on single cylinder machines with a maximum displacement of up to 158cc (air cooled 4-stroke only), otherwise unlimited modifications, with the exception that they must maintain a mini chassis. Maximum wheel diameter, 19" front, 17" rear or minimum size no smaller than stock. Minimum age 12. The only exception is that riders under 12 may enter with 5 years or more of racing experience. XR100 Cup May Bump to Premier Mini. Vintage XR100 Cup will run at the same time as this class.
    XR100 Cup: A, B, or C level rider on and XR/CRF 100 machine with a maximum displacement of 120cc (4-stroke). Original crankcase, head, and original stroke. Modifications are allowed to stock air box, suspension, chassis, exhaust, tires, gearing, jetting, handlebars, hand guards (non-metal, open-ended are recommended), levers, grips and cosmetics, and after-market brake pads may be used. Minimum age 9. Sport Mini may bump to XR100 Cup.
    Vintage 100 (V100): A, B, or C level rider on single cylinder machines with a maximum displacement of up to 125cc 4stroke and 60cc 2stroke (air cooled only) and must have twin rear shocks, otherwise unlimited modifications, with the exception that they must maintain a mini chassis. Maximum wheel diameter, 19" front, 17" rear or minimum size no smaller than stock. Minimum age 12. The only exception is that riders under 12 may enter with 5 years or more of racing experience. Vintage 100 will run at the same time as XR100 Cup or GP50 depending on the event.
    Sport Mini: C level or Novice rider on single cylinder machines with a maximum displacement of 85cc (2-stroke) or 158cc (4-stroke). Original crankcase, cylinder and heads and original bore, stroke, and displacement must be retained. Modifications are allowed to stock air box, suspension, chassis, exhaust, tires, gearing, jetting, handlebars, hand guards (non-metal, open-ended are recommended), levers, grips and cosmetics, and after-market brake pads may be used. Minimum age 9. Sport Mini may bump to Premier Mini.
    There is no dirt section or jumps for the following classesd>
    Open Pit Bike: A, B, or C level rider on single cylinder machines with a maximum displacement of 85cc (2-stroke) and 158cc (4-stroke), otherwise unlimited modifications. Maximum wheel diameter is 14 inches and the minimum size no smaller than stock. Modifications are allowed to stock air box, suspension, chassis, exhaust, tires, crank cylinders, gearing, jetting, handlebars, hand guards (non-metal, open-ended are recommended), levers, grips and cosmetics, and after-market brake pads may be used. Minimum age 12. Stock wheel sized XR/CRF80s may run the class.
    GP80: A, or B level rider on single cylinder machines with a maximum displacement of 110cc (2-stroke) or up to 158cc (4-stroke), otherwise unlimited modifications. Minimum age 12. The only exception is that riders under 12 may enter with 5 years or more of racing experience.
    GP50: A, B, or C level rider on single cylinder machines with a maximum displacement of 65cc (2-stroke) or up to 120cc (4-stroke), otherwise unlimited modifications. Minimum age 12. The only exception is that riders under 12 may enter with 5 years or more of racing experience.
    Middleboro, MA
    I believe this will be the first time they let big bikes run. I cant race on sunday but i figured id bring sprockets and see how it goes friday.
    Ayrton Senna
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    I love rompin the 250F on these tracks... unfortunately due to the lack of organization on ESMRA's part... I was unable to follow the series this year... hopefully they get it together next year.
    For those interested in real SuMo, there's a race Aug 27 in NY @ OVRP (won't be attending due to bachelor party).
    Middleboro, MA
    Is the 27th a njmgp event? Or just a ovrp event.
    Ayrton Senna
    A word of advise: bring everything you will need with you before you get within 30 miles of this place. It totally is in the middle of nowhere, and you can not get better then 87 octane in town. There are no facilities, to plan your shitting accordingly. Aside from that, the place is really fun and the people are cool.
    Unfortunately I can not come out and play this weekend. I haaaave to work on Saturday and Sunday and I am going to swing by Harvard on Friday
    I am in process of negotiating Buying (trading) My 450smr Back and will most likely hit some events with you next season.
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Lake Champlain, VT
    Quote Originally Posted by Dannyf View Post
    ovrp... not the mini endurance thing...
    pm for details.
    Boxshop is a really fun track. Definitely tight and technical, but what's the fun if it's not challenging, right? And the dirt section is awesome! Its not huge but it actually takes a little thought, not just big tables. Come support the track because the owner is adding pavement every year.
    Definitely bring everything you need. I'll be camping there all weekend. Its a really relaxed atmosphere up there.
    I won't be camping, I live all of 30 minutes away, but I'll be there Sat and Sun.
    I'll second, friendly crew and relaxed atmosphere. It really is what pitbiking should be all about, a bunch of friends horsing around in someone's back yard. Only in this case that friend has laid down an awesome course with pavement and dirt sections...
    Middleboro, MA
    well the 450 is done and should pass tech
    at work right now catching some sleep in my truck in the am then heading up
    Ayrton Senna
    So wishing I had suitable tires for the WReck... oh well, the 70 will be good to go.
    Middleboro, MA
    I bet you have more fun than I do. My 13t front sprocket is cooked so ill be running 14/42....
    Ayrton Senna
    Heh... betting you'll have more fun.
    1st practice today, not really pushing yet just working on getting back into the flow. Approaching the right hand 90 down into the new pavement, roll on front brake and grab a downshift at which point I start hearing all sorts of expensive sounds. Immediate clutch grab and get off track. Turns out I did my poor 70 in but good. Intake valve stuck in the head and became quite intimate with the exhaust valve and piston. Had that been all my quick head swap to a stock unit in my garage this afternoon would have had me back for Sunday.
    When I went to locate TDC for timing I noticed the flywheel had a LOT of play... I broke the crank AND the cases. At least when I do it I do it right.
    So much for mini racing this year.
    Middleboro, MA
    That's too bad man. Yea I made a gear change yesterday and had a blast at practice is too bad I couldn't stick around and race.
    Ayrton Senna
    So Danny, will we see you next weekend at nhms?
    And Josh, get your ul machine going.
    Why do you think I said my mini season is done? I'm not cutting into the UL budget!
    Middleboro, MA
    I need to get to a penguin school first. Gotta get my shit together and check out their schedule.
    Ayrton Senna
    Friday before every race weekend.
    Middleboro, MA
    This is good info. sunday night ill find out for sure if I can Thursday off of work. If so then ya ill be there.
    Ayrton Senna
  1. Supermoto Practice 3/27-3/28 OVRP
    By BLACK SQUIRREL in forum Pit Area
    Last Post: 03-30-09, 12:48 PM
  2. Friday practice... 5/11 who's going?
    By Kitt in forum Pit Area
    Last Post: 05-04-07, 02:13 PM
  3. Friday Practice Price?
    By Evil_Weasel in forum Pit Area
    Last Post: 04-26-07, 12:06 PM
  4. Whose going up for Friday practice?
    By senecak19 in forum Pit Area
    Last Post: 04-05-07, 11:17 AM
  5. Friday Practice?
    By Rick Lee in forum Pit Area
    Last Post: 08-10-06, 09:05 AM
