1984 Kawasaki Ninja 900.
I've had the bike for 7 years so I know her well.
My issue as mentioned is the tail light no longer works, but my brake light works. The problem is a wire that after 24 years has broken from its "tang" at the key switch, located on the backside of the ign. key cyclinder.
I have repaired this wire before but it was below where the wire attaches and I had about 2cms of wire to work with. As luck would have it the wire is sheared from its post.
My question is this,
Can I not just go and grab 12v off the wires running to the headlight to supply the tail light with power? Simple enough?
I have extra wire and proper fittings to do the job but I fear getting the end of the wire now back to the key switch attachment point would be quite the trick.
Thanks,
Eric
