Results 1 to 13 of 13
Wrapping up baffles with muffler packing?
    Jun 2012
    Westborough
    I put the Chain Reaction moto GP Exhaust on the Striple. I also installed the baffles which have reduced the sound to a tolerable level. Even so while tooling around town I find it to be a tad bit loud.
    I was wondering if any one has experimented with wrapping the baffles with muffler packing like the FMF 4 stroke muffler packing (fiberglass cloth?)
    Any other way to reduce the sound.
    Arlington MA 02474
    Re: Wrapping up baffles with muffler packing?
    I use the FMF packing (from Cycle Gear) in the EMGO mega-muffler on one of my bikes, basically it's an empty can with a perforated tube down the middle. I have used other packings that I would have to re-do every now and then, like less than 1,000 miles, will see if the FMF last longer. It's mellows the sound, but you can't call it quiet, still has a bark to it.
    I've used the fiberglass sheets. It didn't really quiet it down, but it took away some of the 'sting'. Getting the baffle back into the can was a pain in the ass with the new packing (yes, I tried all the tricks)...
    Durham
    I haven't but it's unlikely to make a huge difference. The amount of packing material you'll be able to get around it is negligible compared to what is already in the muffler. And considering that the baffle works by reflecting pressure waves back into the can where they can be further absorbed or cancelled, wrapping it might actually make things worse (also unlikely but possible). A different packing material might work better as was noted above. I've heard of people using steel wool for it's longevity but that tends to make things louder. There might be something out there that goes in the other direction (doesn't last as long but absorbs sound better)
    Lifer 01xj's Avatar
    CT
    If you got the shorty muffler you are going to cover so little surface area there is no point.
    Jun 2012
    Westborough
    I put in the ear plugs this morning and was happy with the sound (NRR 33), it was almost too quiet which I am not used to, I like being able to hear some ambient sounds for potential danger. Might try a different set of ear plugs. Any recommendations on these? I am currently using Howard Leight Max NRR 33
    Lifer 01xj's Avatar
    CT
    I use similar ear plugs and have never had a problem, I can hear ambient sounds just fine. I don't have any recommendations, I just grab whatever work has that week. Sometimes they are Moldex Sparplugs, sometimes its the Howard Leight brand.
    Jun 2012
    Westborough
    Guess I just need to get used to these
    Lifer 01xj's Avatar
    CT
    You will get used to it and quickly and probably make it part of your regular gear in no time. Not only does it keep you from listening to the exhaust which now points to your right ear, but you protect against wind noise through your helmet which is falls within the spectrum for hearing damage.
    Jun 2012
    Westborough
    Very true, my commute to work being 15 minutes was the primary reason for not putting in the ear plugs but this might just flip the switch on it and turn it into a good habit. I usually carry a few disposable ear plugs in my jacket anyway. might try the webbikeworld recommended E-A-RSoft Gripper ear plugs
    Lifer 01xj's Avatar
    CT
    I skip them for my short commute as well, but I only go 2 miles. I realize that is completely contradictory to what I just said.
    The foam ones I keep until they are dirty and then use a new pair. Most drug stores sell them in reasonably sized packs where you can buy two per season and be good with them. I keep them in my jacket pocket but I am mideful not to put anything else in there like keys wallet or change, just to keep them clean.
    Arlington MA 02474
    Moldex Pura-Fit 6800 is my earplug of choice, buy 'em by the case of 200 pair. For me part of ATGATT.
    Jun 2012
    Westborough
    From now on it will be of mine as well. Took a loud exhaust to help me cross that bridge :-)
  1. Wrapping bodywork instead of painting...
    By jwm2k3 in forum General Bike Related
    Last Post: 06-14-19, 08:32 AM
  2. Vinyl wrapping.
    By loki32687 in forum General Bike Related
    Last Post: 09-29-11, 11:53 AM
  3. Replacing baffles in stock exhaust.
    By cdseven95 in forum General Bike Related
    Last Post: 02-15-10, 06:35 PM
  4. Exhaust Baffles
    By ff36buell in forum General Bike Related
    Last Post: 04-12-09, 11:03 PM
  5. A&R baffles
    By nilez in forum Bike Maintenance
    Last Post: 04-24-08, 04:24 PM
