Results 1 to 4 of 4
Cafe poject finally under way
    Posting Freak tonup's Avatar
    Feb 2008
    Alton nh
    I've had this hardtail for about 20 years and it hasn't seen the road in a long long time. Finally had enough of it sitting there and figured I'll either sell it or make a cafe project out of it. 1970 T 100c. Little 500. Engine is out and being dropped of this week for a major go over and probable total overhaul. Wanted to tackle it myself but a total lack of good heated work space made me think otherwise. I've already found the rear frame section and swing frame and misc. pieces parts. I have no time line and no real budget but I have to start somewhere. Budgets for these things usually turn out to be a laughable joke by the end anyways. Most difficult part I think will be trying to update the electrical mess made before I bought it and seeing if I can change it over to negative ground system. Should be a fun one. Any advice from others that have done similar projects is always welcome. The good advice anyways.
    Attached Thumbnails Attached Thumbnails Cafe poject finally under way-img_2379-jpg
    Lifer jwm2k3's Avatar
    Mar 2004
    Lynn, MA
    Re: Cafe poject finally under way
    Whats you goal for its apearance? Color?
    Durham
    Why are you changing it to negative ground? Functionally there is no difference between the two. With few exceptions (maybe an aftermarket gauge pack or something) anything electrical you buy should be pretty easy to fit to a positive ground. Worst case, you run a separate wire from the battery to whatever you need to power and bypass the ground completely. Especially with how simple a cafe's electrical system is I don't see a benefit to converting. That said, I would think the conversion would be "relatively" simple but I'm saying that without first seeing a wiring diagram.
    Feb 2008
    Alton nh
    haven't even figured that out yet. Have someone with a british racing green frame and better front end which would end some of the work. Just add money. I know it will never be a "pure" tiger again due to needing way to much time and money. My biggest hope is to some day be able to get it on the road and track for nothing more than my own enjoyment. I was done with the hard tail thing years ago.
    As for the negative ground, I don't know how deep this project may go. If things stay as simple as I want then things will be wired somewhat as is. Stuff was rigged before so a good sorting needs to be done regardless. Not to mention my brain automatically thinks neg ground with everything else I wrench on. Just easier in some aspects.
  1. Cafe Racer
    By netra709 in forum General Bike Related
    Last Post: 04-16-10, 09:21 AM
  2. Vento 400 cafe
    By 2v2Ducati in forum General Bike Related
    Last Post: 01-29-10, 03:14 PM
  3. For those looking for a Cafe project
    By JohnnyV in forum General Bike Related
    Last Post: 07-19-08, 12:13 AM
