Results 1 to 15 of 15
Waaa.....I suck at working on bikes.
    Littering and........
    Jul 2004
    Vermont
    So I'm in the middle of trying to change the coolant in the R1, BUT THE FUCKING COOLANT WONT COME OUT.
    The reservoir is half full, and wont drop any. I ran the bike for a minute or two, but got nothing. This thing is supposed to hole 2.5 liters, I have about 3/4 liter in the drain pan.
    What am I doing wrong??
    Take the radiator cap off, dumbass. (johhny says "vacuum")
    degsy
    guy on the vintage Yamaha Rice-rocket1's Avatar
    May 2002
    New Bedford, MA
    degsy
    My ride's
    95 FZR 1000
    19xx DOUBLE "D"
    ... there any more drain plugs like in the resevoir & radiator itself?
    Jul 2004
    Vermont
    I did that.
    Then I tried adding water to the radiator, thinking that would force the green stuff out, and all it did was go right through the radiator and pour out of the drain plug.
    Oh jeez, blind leading the blind.
    What drain plug?
    You need to take off the hose leading from the water pump to the radiator (careful, it will piss out everywhere) and lean the bike over on the left side.
    derek
    i was gonna say "pull the cap off" but i figured he wasn't that dumb
    jk man, you're my ride tomorrow
    Was the cooling system full to start with?
    I just about had a shizznit attack when i saw where the radiator cap was on my 04 R1
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Make sure you get distilled water to refill
    Always have 50/50 lying around its bad paractice to ever put water in in case you forget
    Also regular antifreeze is bad poison and kills dogs if left exposed lso they can get at it
    Glen Beck is John the Baptist
    Lifer Suf Daddy's Avatar
    Nov 2003
    Boston, Lincoln, other locations
    Put pressure on it.
    Blow on the hose you HOSER.......
    -Suf Daddy
    Suf Daddy.
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    Some water pumps have a bleed valve designed for purging the coolant system.
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    Resident Chrome Dome Cue Ball's Avatar
    Johnston, RI
    Last time I changed it, I cheated stuck a small hose ever so gently into the filler hole, and turned on the shop vac. Got pretty much all of it and no spillage.
    Yes, I know, I am a hacker at times, but if your going to piss in the pool, put some pizaz into it and piss off the diving board....
    All I want for Christmas is another rear tire.....
    http://www.ratemythong.com/indexhome.php
    If water went right through the whole system (motor included, then you've gotten all the coolant out that was in there. You'll have to remove the resevior tank to empty it, or syphon the fluid out of it.
    Edit, re-reading your post, I see that your radiator has a drain. Put the plug back in, take the inlet hose off the radiator and spin the starter. This will push the coolant out of your motor. If nothing comes out, it's empty...
    It is possible that you were low on coolant. The resevior can be misleading sometimes...
    May 2003
    Lakes Region, NH
    Bras cause cancer.
  1. HD Theater..Mecum auction.... bikes bikes bikes
    Last Post: 08-18-11, 09:39 PM
  2. Tired of working on bikes...
    By TTD in forum General Bike Related
    Last Post: 10-19-06, 08:51 PM
