Page 3 of 3 FirstFirst 123
Results 51 to 67 of 67
Winter Riding Basics
  1. #51
    Member z3dsp33d's Avatar
    Oct 2013
    Amesbury, MA
    Re: Winter Riding Basics
    Give that a try on a snow covered hill.
    Regardless of how many friends might be around or how small your hill is, that pop part might not work out as easily as you expect.
    Now my experience feels worthless.
  3. #53
    Quote Originally Posted by Rossco View Post
    Winter riding is awesome. A lot of snobs on here are afraid of getting a little bit of salt on their precious Ducatis.
    Wait, I just got a duc with the INTENT of riding it all winter. Am I doing something wrong here?
  4. #54
    I saw a bear in the road, luckily, my headlight illuminated it with time to spare, I was riding my first IBA SS1000 ride, about 3am on Route 9 in Wilmington, VT. Had a closer call with a deer about 5am on I-88 near Oneonta, NY
  5. #55
    Go big or go home.
  6. #56
    Manchester, NH
    If you want some insight and wisdom that's actually applicable you should read some of Ken C's writing. After you read a few of his articles come back and reread your own.
    Most important thing to know for winter riding
    Hypothermia most important concern in gear, crash protection becomes secondary
    Learn the stages of hypothermia, reaction time and mental ability is on par with a drunk, you should not be on road if you are shivering
  8. #58
    Jamnuts jhawley's Avatar
    Oct 2009
    Southern CT
    i rode today to work it was 38. i was nice an toasty with my heated gear
    Durham
    You mean shamu doesn't have heat built in? I woulda figured it did. How else do you justify being the size and weight of a car?
    Quote Originally Posted by soofle616 View Post
    It's all about heat and heat is the result of amps over time. A pack that small can't possible produce 2-400 amps for any significant continuous time so heat buildup would be minimal. However, I agree that what appears to be 10ga. wire is awfully thin for that kind of current load.
  11. #61
    still doesn't make me warm and fuzzy, current draw in a warm garage and current draw trying to crank and engine with frozen thick oil is not the same
    as I've said, I've seen 6 gauge jumpers melt the insulation off the copper, I don't doubt the battery holds the energy
  12. #62
    More to wire sizing than overall gauge. If they're using the good quality stuff made from very thin strands there could be very good current carrying capacity in those wires.
    Now, the clamps on the other hand...
    Oct 2013
    Amesbury, MA
    More Cu less Ni.
    I also realize they are short cables as well, if the wires were gold, sure, 10ga. copper wire just doesn't cut it for carrying a 100 amp load for more than a few seconds
  15. #65
    You are assuming this is like a conventional battery that doesn't have any circuitry to control current flow, both charging and output. It isn't.
    There are some people that are late adopters and not comfortable with new technology. This is not for those people - they can continue to carry around 12-18 lb AGM batteries.
  16. #66
    its the starter and its work load that determines the current draw thru the jumper wires , not the battery
  17. #67
    Lifer Falko's Avatar
    MoonTown
    So in the summer you use..?
    60W-90
    In my rear diff....
  1. Ice Riding Basics
    By Ken C in forum General Bike Related
    Last Post: 02-02-15, 08:53 PM
  2. Ice riding winter 2012-2013
    By RandyO in forum Dirty Bastards
    Last Post: 02-24-13, 09:04 AM
  3. Basics of Motorcycle Riding - Informative Speech
    By ninjachica250 in forum General Bike Related
    Last Post: 02-17-11, 12:40 PM
  4. Winter coming ICE RIDING
    By KB in forum Dirty Bastards
    Last Post: 03-10-09, 02:30 PM
  5. This would be fun for riding in the winter!
    Last Post: 11-21-05, 01:02 AM
