Page 7 of 8 FirstFirst 12345678 LastLast
Results 151 to 175 of 200
Doc's Garage tear down/ rebuild thread.
  1. #151
    Just Registered Doc's Avatar
    Jericho, VT
    Re: Doc's Garage tear down/ rebuild thread.
    Updates
    Gained some yard
  2. #152
    Posting Freak yesterdayze's Avatar
    Milton Vermont
    Cool, glad to see it getting there. Hope it handles that weather well Keep the pics coming!
    Lifer BostonSVkid's Avatar
    Dec 2005
    Why the foam on the concrete walls?
    2006 Ducati Monster S2R800
  4. #154
    Jericho, VT
    Doing everything I can to keep it warm and free of ice/frost
  5. #155
    Milton Vermont
    That's pretty standard, well, at least up here. The insulation helps to isolate it a bit which of course keeps it a little less damp as it is not as cool.
    Jericho, VT
    I doubt it is going anywhere as far as frost heaving is concerned...
  7. #157
    Dec 2005
    Quote Originally Posted by yesterdayze View Post
    I understand the standard part/code but with it being unconditioned space it shouldnt make much of a difference.
  8. #158
    Jericho, VT
    Oh I am gonna heat it. Got a 45,000 BTU Propane heater.
  9. #159
    Dec 2005
    heat it 24/7 during the winter? The garage and the mini basement?
  10. #160
    do you have an A/C unit for wrenching around during hot summer nights?
  11. #161
    Dec 2005
    just curious...how thick is the slab on top of the footing? Whats the total depth of the slab over the soil?
  12. #162
    Are you just searching for something to complain about?
    Lookin good, you will enjoy it. Doc's a big boy(i've seen pictures) and im pretty sure he has no reason to not trust his contractor.
    Dec 2005
    Quote Originally Posted by MysteriousR1 View Post
    I have a degree in civil engineering and I do construction for a living. I am just curious. Always looking to see how people do things differently.
  14. #164
    Lifer Trouble's Avatar
    Monkton, VT
    Looking good Doc! Excited yet?
    LRRS EX #7
    Low Down Racing
  15. #165
    Jericho, VT
    About 8 inches over the original footing. Pretty sure it is 20 inches thick.
  16. #166
    Jericho, VT
    Quote Originally Posted by Trouble View Post
    I'll be more excited after this week. I expect ALOT to get done this week.
    Bonus: I parked the 998 on the slab and I might be able to fit full sized bikes under there! I know the Hawk will fit.
  17. #167
    About 8 inches over the original footing. Pretty sure it is 24 inches thick.
    slab is probably 8 inches thick at the most, maybe 24 inches with the footing together. there is absolutely no reason to have a slab that thick. most house, basement slabs are only 8 inches. look at the boots of the guys in your picture, about ankle height, assuming around 4 inches, with the rebar in the middle, 8 inches sounds about right.
    there is tar/sealant applied to the outside of the wall, then foam board is put on to help insulate. helps keep ice/water from pushing into the concrete too much and help insulate it to keep it from cracking. should be backfilled with sand to help water drain, on top of perf. pvc pipe, with some 3/4 or 1 inch stone around it, wrapped in fabric for a footing drain.
    my family has a construction company (gramps/dad/bro work it). I've helped/worked on foundations, septic systems, curtain drains, slabs, precast boxes etc...
  18. #168
    Jericho, VT
    I'll measure tomorrow but everything else you said was done.
  19. #169
    if you measure what's exposed, you aren't getting the true slab thickness. You'd be measuring the footing along with the slab, or as in the south side of your slab, its a little thicker because there is no footing. so to speak, the footing is poured into the slab similar to if you had a floating slab.
    floating slab constructions would be probably 12-16 inches on the outer edges with hoops of rebar as a "makeshift" footing. they will also pour the concrete on top of foam board to insulate the floating slab as well, similar to what they did on the sides of your foundation.
    Jericho, VT
    I can see where the footing was and how much covers the footing now. Should of had them poor on top of foam huh?
  21. #171
    Make Wheelies Hazen's Avatar
    Feb 2010
    Vermont
    Cool project / improvement.
    Maybe it'll be done by the time I get up there.
    Dec 2005
    Foam for a thermal break under the concrete slab is not necessary. It couldnt hurt but not necessary in such a basic structure.
    For such a basic building I wouldnt be too worried.
    Good luck I am jealous that you will have a nice garage soon!
  23. #173
    Jericho, VT
    That is the main thing I had to come to grips with.
    I trust my Dad, he came over and looked at it and said that is MUCH better than the way it was and it should be good.
    I really appreciate the input though guys.
  24. #174
    like SV said, I wouldn't worry about it. I was just giving you more info, sorry to make you worried.
    don't be scare when the floor cracks though, its going to happen at some point, almost all concrete slabs/floors do, its normal.
    Dec 2005
    Quote Originally Posted by jcbell1007 View Post
    Yup and that is what rebar is for. Whatever ANYONE tells you dont even let them say fibrous concrete is sufficient with no welded wire mesh or rebar.
  1. 2014 Garage Connection Thread
    By Kurlon in forum Pit Area
    Last Post: 06-13-14, 04:51 AM
  2. Another garage thread
    By Kurlon in forum General Bike Related
    Last Post: 01-27-10, 01:53 PM
  3. ex500 tear down
    By daviid in forum Pit Area
    Last Post: 06-25-06, 12:10 PM
