Results 1 to 25 of 35
Any tards running a 5.5 rear?
    Lifer lopycam's Avatar
    Aug 2003
    Cow Hampster
    Hi Guys,
    I am considering purchasing a set of motard wheels for the YZ. The set I am looking at is a 17x3.5 front and a 17x5.5 rear. The front is very common. The rear seems to be very wide. The guys says that these fit an 06 YZ450F with out rubbing using a 520 non oring. My gut is saying that I should stay away from these because the rear will be too wide. What tire would I run on this anyway, 180? That seems too wide. What do you guys think?
    Thanks for the advice in advance.
    Nathan
    Freak Posting snowborder's Avatar
    Mt. Wannahuckaloogi
    Re: Any tards running a 5.5 rear?
    search this topic on supermoto junkie .... or ask there you will get a wealth of info... seems wide as most 160 tires show signs of rubbing
    Where in NH are you?
    2001 RC51!!!
    2007 Husky SMR 510 - no longer... blown tranny
    You're not going to just bolt that one on and not have to worry about anything. I have a 5" rear on my YZ, 160 tire and a 520 non O-ring chain and I had to space the sprockets 1/16", use a Graves chain block and even had to shave a bit of the tire with a block plain. I have less than 1/16" clearance between the tire and chain.
    Also, I don't even see you getting that in the swingarm without a major pain in the balls. The 5" with a 160 is a pain as it is.
    While I think it would look killer on the YZ, I'd stay away from that sized rim
    Aug 2003
    Cow Hampster
    I have already asked at SMJ. I am just trying to get a few different opinions.
    I am in Nashua.
    Thanks,
    Nathan
    Nov 2004
    Boston, MA
    I don't know the bike specifically, but I did a bunch of searches on sizes for rims when I bought new ones and the general consensus was 5.5 too big.
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    There's no way it's going to fit in a stock swingarm. I'm maxxed out with the set up I have as far as room. I also forgot to mention that when my wheel was laced up, it was set up offset from center to reduce the chain rubbing issues.
    This picture may give you an idea just how close it is?
    live to ride seth399's Avatar
    Feb 2007
    CA
    I don't know how people do it, I have a 5.0 on my crf as well and don't see how I'd go bigger really. I almost bought a crf already in supermoto form that had a 5.5 rear but I never got to see it in person before it drown to death.
    LRRS #399
    MX #505
    Jun 2005
    yeah, I'm with stupids. Can't see anything beyond a 160 fitting on a typical motard. Some 160's (Power Race for example) won't fit without a fair amount of coercion. I wouldn't really be too stoked about putting a 160 on a 5.5" rim... Seems like you're already leaning towards passing on the deal. I would.
    Both Mark R7 and Seth would find out that "most" Tire company slicks Run a Little narrower then DOT's. a 160 slick would fit better then the Dots they are running. Street tires (corsa III, Pilot powers ect) alway Run the widest. That being said I dont see any benifit to a 5.5 Rear that would still be a Pain to deal with.
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Lifer Pittenger5's Avatar
    Austin
    Eric had a 165 Dunlop on the RMZ. Some chain rub, but not a ton.
    Zip Tie Alley #505
    Jun 2005
    Why you splitting hairs Dolla Bill?
    KR108's are quite a bit narrower (at a listed 165 width) than a Power Race (at a listed 160 width). As the squirrell of darkness points out must slicks are narrower than their DOT counterparts. I'm just trying to keep things simple. I'll stab you.
    Feb 2007
    CA
    *passes tricky mike a shiv*
    LRRS #399
    MX #505
    When Seth Had His Diablo DOTS mounted at Tricky Mikes we measured the Mounted DOT VS the Dunlop 165 Also Mounted And the Diablo was MUCH Wider
    ** Gets shiv From Tricky Mike and Wipes the Blood Off**
    Austin
    Wirelessly posted (BlackBerry9530/4.7.0.75 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105)
    I shouldn't have looked at tricky mike like that.
    Zip Tie Alley #505
    Aug 2003
    Cow Hampster
    So, it sounds like I should stay away from the 5.5 inch rear. That is what I thought. Kirk from factory pro says that a 5.5 rear will fit. I am not conviced yet.
    I do currently have a set or tard wheels and the rear is a 17X4.25. I guess I will just stick with these for the time being unless anybody can change my mind.
    Thanks for the help guys.
    Nathan
    Quote Originally Posted by lopycam View Post
    Nathan
    I dont think The wheel is the issue, Its the tire You put on it. I Dont know what the profile of a 160 Slick would do on a 5.5
    Jun 2005
    Yeah, I'd pass, personally...
    It might fit, but I don't really see the point. It's not so much whether a 5.5 would fit, it's that a 180 tire has no chance of fitting, and isn't needed for a bike putting out motard HP... and mounting a 160 on a 5.5 would result in a flatter profile that the manufacturer hadn't intended. The net result would be that for the additional unsprung mass due to the wider rim and hassle trying to squeeze it into the swingarm you get no reward. Unless, of course there's a legit reason for running the 5.5 and flattening out the profile of the rear tire. I dunno Is this one of those fast guy mods?
    Any chance the tilres buldge will be decreased by squeesing the 160 on a 5.5 and give yo a little more clearance. Come to think of it. I have seen Alexs rear rim (not a 5.5) and it is all beaten up from the chain. Going wider is going to create more of a problem.
    Degsy mentioned to me that he put a 160 slick on my 600 rr and it was flicken machine. I'don't know if I want to do that.
    165 slick. It was awesome.
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    5.5" wide rim on motard = FAIL
    Boston --> San Diego
    Austin
    You run a 5, right
    Zip Tie Alley #505
    Feb 2007
    CA
    You run a 5, right
    he runs a 4.96750 actually, its better than yours
    LRRS #399
    MX #505
    Austin
    Quote Originally Posted by seth505 View Post
    I have the Michael Johnson specials though.
    Zip Tie Alley #505
    Feb 2007
    CA
    hot damn
    LRRS #399
    MX #505
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Yes I have 5" rear wheel on my RMZ.
    250's = 4.25
    450's = 5
  1. 09' R6 Running like sh!t
    By Fastsc92 in forum Bike Maintenance
    Last Post: 11-29-10, 09:52 AM
  2. School me on Tards
    By theducman in forum General Bike Related
    Last Post: 07-05-10, 05:59 PM
  3. rear brake pedal/rear light not working
    By seth399 in forum Bike Maintenance
    Last Post: 04-10-08, 09:57 PM
