Results 1 to 22 of 22
Brake Pad Suggestions Requested
    Haverhill, MA
    I am looking to buy new brake pads for my Motard and figured I would ask for opinions on what has worked for others in the past.
    The bike: 06 Husqvarna SM510R
    The brakes: Brembo four piston four pad radial mounted calipers
    Looking at EBC's site they reccomend the FA322. Ferodo FDB2120 or FDB2215 or FDB2255.
    Any suggestions?
    Thanks
    Joel
    Member peterz85's Avatar
    May 2011
    East Hampton, CT
    Re: Brake Pad Suggestions Requested
    Vesrah RJL
    Pete
    Lifer smf's Avatar
    Nov 2006
    loved vesrah pads on the hawk. don't remember which ones i used though.
    Scott
    Lifer lrrs313's Avatar
    Asheville, NC
    I think I ran Ferodos the last time I changed them on my ktm with the Brembo caliper. Remember that you don't want too much initial bite on the tard. You can end up slowing down too much.
    -Brian
    15 S-Works Venge
    Vesrah RJL, Galfer HH or, EBC HH.
    Jun 2005
    Vesrah SRJL if available. I'm running a set of Carbone Lorraine pads now, which are comparable, but not quite as good as the SRJL's. The SRJL's also LAAAAAAST. We'll see how the Lorraine's hold up...
    FWIW I'm on a set of CL that have 3 years of racing and track days and only are at 50%.
    Lifer Expat's Avatar
    Mar 2007
    Do you bother to brake? !!!!!
    I've used virtually nothing but EBC HH's for the last few years... Made the switch to Vesrah RJL's (they dont make the SRJL for my calipers) and I dig em. A little more bite and a little more stopping power. They seem to be lasting quite well, too. Seems to be what the majority of SV guys use.
    Once these wear out I might consider going over to Carbone Lorraine if they've got anything that fits.
    Posting Freak Puppet's Avatar
    Oct 2004
    Seattle Area
    I love the Carbone Loraine's on my SV, but I'm not sure they have a 4 pad version (could be wrong). I've run the Ferrodo's for years on the KTM and they work great (same caliper you have).
    Brian
    LRRS/CCS EX #881
    WMRRA EX #281
    Quote Originally Posted by Expat View Post
    No. It makes you go faster.
    Member STREET&COMP's Avatar
    May 2010
    Troy, New York
    Here is the question when it comes to pads. How do you like to brake? Brake late with high initial bite or trail brake with a linear compound. Then what rotors do you have? And finally how much do you want to spend? You have Metal Sintered and Carbon Lorraine/Carbon Metallic/Organic. Most pad companies make both, some only make one. Carbon pads are softer on rotors and need less heat for the compound to do what it has to (ie: initial bite, linear). Sintered pads are harsh on rotors and tend to need a lot of heat on the compound to get working which in return = more chance of fade. It is all preference and what works best for your set up. Odds are an organic pad is going to work best for the Tard, not as heavy of a bike and they offer more control when braking. Vesrah RJLs might be a little over kill on that thing. You need any more info or compare certain pads and compounds let me know.
    Jun 2005
    good to hear... and for what it's worth i bought the CL's cuz you were rockin' 'em
    Haverhill, MA
    First off, thank you to all of you that have responded. Not that it cleared up my situation any but I do appreciate the replies and knowledge.
    Quote Originally Posted by STREET&COMP View Post
    Oddly enough I would say a combination of the two is what I try to do. I try to brake late and then trail it off into the corner
    I have the stock Brembo 320mm semi floating rotors. I say semi floating because there is a dab of some type of epoxy or glue of some sort on the buttons from Husqvarna ( I assume to keep the noise down on their "street" bikes )
    Not too much of an issue as this is my race bike and I really like to be able to slow down when I have to. Hopefully they will last a while as well.
    I am not certain what is on the bike stock but the sintered pads have worked well for me on my street bike. If you have any part numbers and prices for the Sintered and Carbon options that may be helpful as well.
    Thanks for the detailed reply!
    Joel
    Lifer smf's Avatar
    Nov 2006
    so does all this mean the huskey is returning?
    Scott
    Haverhill, MA
    Quote Originally Posted by smf View Post
    Husky has been back and racing since the end of last year. Did the last race weekend of the year in 2010 and have doen the first 2 weekends so far this year. I will likely have to miss the July weekend but plan on being at the rest of them.
    May 2010
    Troy, New York
    Joel
    Hey Joel,
    Performance Friction (Carbon Metallic) 7535.95 Compound/ 7535.05 Compound/ 7535.07 Compound is $66.56 per card
    Vesrah (Sintered) VD986SRJL is $116.66 per card
    EBC (Sintered) FA322/4HH $53.99 per card - EPFA322/4HH $85.50 per card
    Lifer smf's Avatar
    Nov 2006
    nice! where ya pitting?
    Scott
    Haverhill, MA
    Same place I used to pretty much. When you come out of the tunnel and reach the top of the hill take a left and we are on the corner before the last right down towards the winners circle. Pitting with Adam Clark, Heath Smith, Bill Morey and BrianC.
    Haverhill, MA
    Hey Joel,
    When you say per card does that include four individual pads or eight individual pads? Just trying to figure out what I need on a motard with only one front caliper.
    Usually a card covers one caliper.
  1. ‘99 SV 650 Carb help requested…
    By RadHawk in forum Bike Maintenance
    Last Post: 05-30-13, 08:09 PM
  2. My bike photos as requested by some
    By jcrawford in forum General Bike Related
    Last Post: 09-17-11, 10:29 AM
  3. Rounded-off Brake-pad Retainer Bolt Removal Suggestions?
    By dhawks in forum Bike Maintenance
    Last Post: 08-24-10, 10:16 AM
  4. As requested.....
    Last Post: 06-09-10, 09:30 PM
  5. Brake pad suggestions?
    By ancosta in forum Bike Maintenance
    Last Post: 08-30-05, 07:39 AM
