Quote:
Originally posted by zx1012r
When I took the advanced course last fall I learned a lot of valuable braking tecnique.
Eric told us to initially set the front with the front brake, and then squeeze as HARD as you can for a short distance, then start trail braking as you turn in. He called it "killing" the brakes. Then keep moving your brake marker up until you are at that point where it all flows through the corner.
I know I was braking hard before I took the school, but after I was braking way later than before, and keeping my corner speed similiar if not more than before. I think I thought that squeezing as hard as I could would lock the front, but like he said, even on his superbike with the brakes that has he can't lock the front with that initial hard sqeeze, due to gyrosopic effect and weight transfer.
Like he said, if you are not braking as hard as you can, or accelerating as hard as you can, then you are coasting, and that isn't fast!
that must kill ur hands.
