Results 1 to 8 of 8
COLIN EDWARDS' 10 (OR SO) COMMANDMENTS
    May 2012
    From Cycle World
    1.
    Eyes up! Look where you want to go.
    2. Smoooooth inputs are key: slow on the gas, gentle-onset braking.
    3. Blend brakes and throttle to minimize the time from off-brakes to on-throttle… which leads to finding neutral throttle. Advanced technique: Crack the gas open before you’re all the way off the brakes.
    4. Throttle control keeps the chassis steady! From off-throttle to pinned is one constant motion. Once you’re opening the throttle, neutral is okay but rolling off is a no-no.
    5. Elbows out for maximum control, and grip the throttle like a screwdriver, not a caveman club.
    6. Scoot to the front in the turns, sit on top of the bike and understand why Valentino hangs that inside leg off: It’s a balance pole.
    7. Compress the fork with the brakes and your weight to steepen rake and make the bike want to turn. In the dirt, use both brakes in every corner.
    8. Push the bike down while keeping your spine perpendicular and shoulders parallel to ground; again, we’re sitting on top of the leaned-over bike. (Body position in the dirt is the only thing that doesn’t transfer to roadracing.)
    9. Weight that outside footpeg!
    10. Slow down to go fast. (This doesn’t work for really slow people, who should attempt to go faster.)
    11. Relax. You’re not really rolling ’til your TT-R is rocking. Your bike will tell you when you’re on the edge, but you can’t feel it if your body is ultra-tense.
    12. Keep close track of your tire pressures but even closer track of your opponents’ tire pressures…
    5 and 9 are my two main areas to focus on this year. Anyone getting on the gas before they are off the brakes or is that WSBK/GP level riding?
    Lifer Pittenger5's Avatar
    Austin
    Re: COLIN EDWARDS' 10 (OR SO) COMMANDMENTS
    That cant be Colin, not one fuck or shit in the entire thing? I call BS
    Zip Tie Alley #505
    Fuckin' right!
    Lifer JettaJayGLS's Avatar
    Tahoe City
    I like this. Curious to see where it goes.
    Junior Member BackMarker-943's Avatar
    Sep 2012
    CT
    Question Re: COLIN EDWARDS' 10 (OR SO) COMMANDMENTS
    I don't know about #12 ??
    I would think tire pressures needed for one persons bike may need to be different than anothers , due to riding style , suspension set up .., rider weight ..., no ??
    As for getting on the gas while braking .., I never did that back in the day .. I was either on the gas .., or on the brakes ...., no coasting ..
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    FYI this is from his Boot Camp and riding TTR125's (thou many apply to big bikes) Your tyre pressures have a nasty habit of changing right before Superpole.
    Senior Member Brendin87's Avatar
    Sep 2011
    New York
    Explains why I'm so slow.
    Tahoe City
    Quote Originally Posted by Brendin87 View Post
    You got #6 down
  1. Colin Edwards is a funny fucker.
    By Doc in forum Pit Area
    Last Post: 07-20-11, 09:26 AM
  2. Colin Edwards is a comedian!
    By gregp in forum General Bike Related
    Last Post: 06-20-11, 10:26 AM
  3. Arai RX-7 Colin Edwards M (White)
    By MotoFreak in forum For Sale
    Last Post: 09-15-09, 12:28 PM
  4. Colin Edwards
    By DesmoTull in forum General Bike Related
    Last Post: 09-01-09, 10:36 PM
  5. I wonder what size boots Colin Edwards wears...
    By Proulx06 in forum General Bike Related
    Last Post: 06-28-05, 08:20 PM
