I know he races the same bike as me so I thought he should know, but that is why I'm asking, so as to make sure I don't show up unprepared.
Yes, the drain holes are there in case it rains, but the vent hoses aren't venting oil. One is fuel, and the other is water (coolant).
Yeah I hear you, but there just isn't anywhere "out of the way" on this bike!
LRRS am #121
On the topic of LRRS racing, am I the only one starting to worry about our April race? I don't know if they'll plow that track, but I'm starting to wonder where we'll be in April. We have 3+ feet on the ground right now, with more storms to come.
They have had to plow the track for the SCCA event that was the weekend before the traditional first LRRS weekend. Not sure how well that would work for bikes though. Do snowbanks work kinda like airfence?
-Brian
15 S-Works Venge
Brian - CEO is right. These other guys are on motards and have a different prep to adhere to.
My CBR has passed tech numerous times without a catch can. All tubes run directly into the belly pan.
You are all set if your belly pan has 5 quarts of containment.
Hate to do this but gotta disagree with ya Bergs.
Your belly pan is not legal to call your catch can for your vent tubes. If it were, can you show me how you vent it into your airbox if present, and if not how you vent it into your carbs, again as per the rules?
Weather or not you 'pass tech' does not mean your legal, again, covered in the rule book. Tech is not ment to certify you're compliant, it's ment to try and catch any safety problems before you go on track.
Winter needs to fucking end.
Sorry I lied to you, Brian. A minimum of 3 quarts of containment is what you need.
No one is arguing that you need a belly pan. I'm saying the rules I quoted earlier covering catch bottles for things OTHER than your crankcases need to go to separate bottles or straight into your airbox.
So, again, if your belly pan is your catch bottle, how are you venting it to either your airbox or carb intakes?Originally Posted by LRRS Rulebook
My airbox is fully enclosed w/about 1/2 inch of space around the air filter.
The belly pan is a catch can. There is no restriction on maximum size of the catch can, so a 3 or 5 quart catch pan is just as good as a 350ml bottle. If a drip or two of fuel or coolant (water) were to get into my belly pan, I think it would evaporate before it ever hit the track, if it could even escape the pan. Now in the event of a wet race, they allow the pan to have drains, and are then obviously not caring that a whole shit load of oil would leak onto the track in the event of a crankcase failure, so a couple drips of fuel mixed with the water in their? I don't know, just want to pass tech, I don't think I've ever even seen anything come out of those vent hoses except when overfilling the tank.
I don't believe the catch cans need to be vented into the airbox, and def not the carbs because my bike is fuel injected and doesn't have carbs. I am guessing that in the rulebook they are just pointing out options for ways to do it, not dictating that their needs to be a vent on the catch can. I'd have to look again, but I'm not going to worry about it.
LRRS am #121
If you have your airbox still, route the lines into there, done.
If you're calling your belly pan a catch bottle, enclose it, run the vent to the airbox as per the rules... except then it's not viable as a belly pan... shit... huh, guess that doesn't work does it?
Not sure what to tell you Josh. I know numerous MW machines in particular that are set up the same way and all pass tech without issue.
The belly pan can be used as the catch can as I don't see anywhere where the rules state the dedicated catch can, should one be used, must be enclosed.
I saw what you posted. I read the rule book every year, cover to cover.
The rules do not specify that the catch can must be enclosed. The rules do however suggest that if you are not using some sort of containment (belly pan, catch can or otherwise), the lines must be run into a sealed air box which would prevent the fluids making it to the racing surface in the absence of dedicated fluid containment.
It's all about interpretation, IMO.
i have a bunch of catch cans...3 of em. not one goes into my airbox. that is all.
Don't bother, I will.
I'll take that to mean "Just route them to the fucking belly pan"On 4 stroke machines all vent, breather or overflow tubes coming from the engine, transmission or radiator must
be routed into a heat resistant catch can of at least 350cc capacity OR the air box.
And I'll wrap it up with a big ole
WHO THE FUCK CARES? JUST DON'T BE A DOUCHE AND DUMP ANYTHING ON THE TRACK. NOW SHUT UP AND GO SHOVEL SOME FUCKING SNOW
Now now, Pete there is nothing wrong with this thread. look how much entertainment it has brought to all of us.
p.s. there is still only 72 days![]()
Don't make me break your grill again.
Is discussing the interpretation of the rulebook some kind of problem?
