Page 6 of 9 FirstFirst 123456789 LastLast
Results 126 to 150 of 214
Countdown until the 2025 NEMRR season!
  1. #126
    Re: Countdown until the 2025 NEMRR season!
    29
    28
    Round 1 registration is open!
    Forks handed over to an expert, picked up a shock, and started tearing the MT apart today. WOW some bits are way heavier than I would have expected in 2025. Wish I knew how to weld aluminum, would make plate mount fabrication sooo much easier.
    I can put you in touch with two excellent welders if you're in need.
    I may take you up on that if I get something mocked up as a workable reference.
    27 glorious spring days to NEMRR
    Registration may be open but not if you need to do your Rookie Race! Ask me how I know!
    26
    Yay for parts that don't fit... mumble grumble...
    If it helps any, I completely spaced ordering that spanner nut socket so, loose swing arm and steering hardware at the moment.
    I dumped the cooling system for a 3rd time after the trust situation I had with the clamps (all set now, BTW). Still need to purge the air out.
    Number plates arriving some time this week, hopefully.
    Also discovered my superbike tail is scratching the hell out of the tank so, gotta look into a better attachment method.
    Still need to do the fiberglass repair on the upper fairing and this new job of mine is taking up all my free time to get it all done!
    Fighting the desire to do everything perfect, and do everything to be MotoA done... when instead what I need to focus on is get it basic track safe, then NEMRR legal, THEN worry about anything else.
    A length of fuel line sliced the long way around the offending tail piece where it contacts the tank? Too cheap?
  12. #137
    I'll post a pic. It's how its mounted along, with the lack of hardware to secure the seating area.
    Also....
    25 days!
    Countdown until the 2025 NEMRR season!-22be35c2-cf87-4bbd-abe7-bf8d4d8e179f
    Slackin'!
    Countdown until the 2025 NEMRR season!-aaron-yates-jpg
    Countdown until the 2025 NEMRR season!-photo-sep-11-2020-22-a
    Lifer FirstDuc-1098's Avatar
    Central Mass
    Countdown until the 2025 NEMRR season!-fb_img_1743863067232-jpg
    Shit Corey says:
  16. #141
    Countdown until the 2025 NEMRR season!-images-jpeg
    Exhaust mounted (I hate systems that have separate spigots, brackets and use springs to tie the headers to the spigots…), Belly pan mounted, forks brought home, still so much shit to do…
    Countdown until the 2025 NEMRR season!-2322274568_683c551b98_b-jpg
    Cool... torque wrench shed an e-clip at some point... mumble grumble...
    Countdown until the 2025 NEMRR season!-images-1-jpeg
    Countdown until the 2025 NEMRR season!-sportscout-7-jpg
    WMC original sdog30's Avatar
    Burgy
    That's the 18 you used? Probably would have gone Jett Lawrence on that one. You're slipping, bud.
    LRRS/CCS #66
  23. #148
    365 days until sdog30 starts the 2026 countdown
    A detail I hadn't thought of... back in the day Street And Comp sold generic number decals... does anyone still carry them at the track?
    I'd guess Seacoast.....at least that's where I picked up mine for the Super Street weekend I ran
