Has any one ever put a roof mounted AC unti on thier race trailer? Whats involved? Whta parts do yuo need? I found this one through JC Whitney, Does it come with everything i need? Thanks http://www.jcwhitney.com/airv-low-pr...p2014909.jcwx#
Buy an a/c at home depot and make a door for it to fit in your doorway.
Talk to R7 I think he had this setup.
I thought about doing a home AC unit in the front of the trailer but this roof mount is not that expensive and would look better. I have the money i just need to know if it comes with what i need to make it work? Thanks KB, any luck on a rear rotar?
It should be straight forward install! As for if it has everything, call the manufacturer and make an inquiry!
Performance: 1397 JE bigbore, Dual Intake cams, Adjustable cam spockets, Sm air box mod,Pc3 usb,Ingnition box w/hub, and Lcd screen, Hindle stepped race header, Dual Fans, 24 volt starting
Suspension & Brakes: Ohlins road and track forks, Ohlins rear shock, Sprint top mount dampner, PRM top clamp, Dymag Carbon mags, Brembo HP rotors, Brembo Hp radial calipers,
Show & GO: Topgun undertail, Libertek led lights, Pazzo lever, PMR Switches & Kill,PMR cover. Revolution Custom Paint, Harris Grips.
Cut a hole. and wire it up. Make sure you get the gasket so you don't get any leaks.
let me know how it works for ya. ive been wanting to put one (or 2) on the bus for a while now.
will do, surprised you dont have a 60,000 btu on there already
RV places have them in stock usually.
If loud pipes save lives, imagine what learning to ride would do.
Wirelessly posted (Instinct: TELECA-/2.0 (BREW 3.1.5; U; EN-US; SAMSUNG; SPH-M800; Teleca/Q05A/INT) MMP/2.0 Profile/MIDP-2.1 Configuration/CLDC-1.1)
I think rv places want more money but to be honest i havent put much research into it but $200 seems like a good deal.
i have a house ac that i got for the bus but have been struggling to figure out where to put it. a roof mount would be ideal
