Results 1 to 25 of 38
Fixed My Brakes
    Smile Fixed My Brakes
    only cost me a right peg.
    For those who know, i've had a wicked bracke fade issue my last 3 track days. rebuilt the master, replaced the master, replaced the fluid twice, and still nothing. Now I'm good to go...
    Replaced the blue rotors, the stretched brake lines, boiled fluid, pinched caliper seals, and the worn our pads.
    had 4 pinched seals, causing the pistons to not retract after braking. dragging pads caused the rotors to overheat (turned blue) and boiled the fluid.
    new stock rotors were scrubbed in nicely with 60-grit sandpaper.
    Goodridge superbike lines replaced with Goodridge -2 lines
    Brembo fluid replaced with fresh fluid
    calipers rebuilt.
    new PF pads in 07 compound
    Goodridge speed bleeders
    new clear Brembo brake line hose for the cup --> master
    bled the shit outta the system, but kept getting air out of the right caliper. Rode at Thursday practice and would crack the caliper bleeder after each session. still getting air pockets and a soft lever.
    went out for a session in the wet, and had a lowside when I whacked the throttle out of T3 on the 1st lap. Picked up the bike and saw a massive air bubble in the brake reservoir hose. Rode back to the pits to push the air bubble to the reservoir cup. Now I'm back to 1 finger braking
    still cracking the right caliper after sessions & getting small air bubbles, but the lever is much better now.
    Thanks to those that helped me at the LAPS and BoMo days trying to get the braking issue sorted.
    Just Registered Omahastylin16's Avatar
    Apr 2008
    Scituate, MA
    Re: Fixed My Brakes
    sounds like a lot of work
    "Chatbox...It's like Vegas, for your fingers."
    Originally Posted by CBR_Knight
    in my own thread, let me post this:
    first of all, nothing about sex or play with a female seems interesting or arousing to me....
    "BALLS" is coming home late after a night out with the guys smelling of perfume and beer, lipstick on your collar, slapping your wife on the ass and having the balls to say "you're next!"
    Re: Fixed My Brakes
    Quote Originally Posted by Omahastylin16 View Post
    and a lot of $$$.
    I can't wait to ride it
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Re: Fixed My Brakes
    I hate air bubbles. bleeding new brake lines is my least favorite thing to do. I can't wait to curse and start throwing shit when I swap my Brembo m/c over to the new bike. just thinking about it is pissing me off.
    Re: Fixed My Brakes
    by far, the worst is bleeding the calipers after a rebuild
    Feb 2008
    Las Vegas
    Re: Fixed My Brakes
    Soooooo, what you're saying is;
    "One has to crash to get their brakes properly bled after buying a entire new braking system."
    You should start putting a book together. Jimmy's Super Motorcycle Repair Manual.
    Carpe Diem
    '10 Yamaha R6-Race-
    Re: Fixed My Brakes
    Chris's suggestion for dirt bikes may be applicable here: Pop the offending caliper off, open the resivoir cap, and push the pistons on the problem caliper all the way in. Pump'em out, shove'em back in. That should hopefully force whatever air is left in there out. Plan B: Ziptie that lever right to the bar for a couple nights, then crack the resivoir and snap the lever a few times and hopefully that'll get the bastards out too.
    Bridgewater, MA
    Re: Fixed My Brakes
    Quote Originally Posted by Jimmy 2 Shots View Post
    yeah beginning of the year I did new m/c, new lines and rebuilt the calipers. god that sucked.
    Re: Fixed My Brakes
    ya, rebuilt the calipers on my street bike this winter & still crack the bleeders every couple hundred miles
    Uxbridge, MA
    Re: Fixed My Brakes
    you obviously suck at doing this then... I've never had a problem like you do w/ brakes....
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    Re: Fixed My Brakes
    Jim I know you got an older Gixxer but I've flushed the fluid a couple times to put in fresh brake fluid and couple months ago I installed new SS lines. Had no issues getting the bubbles out when I installed the SS lines.
    Feb 2006
    Metro West, MA
    Re: Fixed My Brakes
    Forgot to mention that the vacuum pump tool that I used to use on my CBR's calibers worked great. When I used it on the Gixxer's caliper's it didnt work for shit. Had to use the old school method of squeezing the brake lever, cracking open the bleeder, close bleeder, release brake lever, repeat.
    Bridgewater, MA
    Re: Fixed My Brakes
    Quote Originally Posted by Billy View Post
    mityvac didn't work for shit on my Honda even after getting fluid coming through the lines. I suspect it might have been the speed bleeders acting against the pump.
    Feb 2006
    Metro West, MA
    Re: Fixed My Brakes
    I had a 99 CBR 600 F4. I'm guessing the design back then worked with the tool. I know on my 06 Gixxer when you crack open the stock bleeder it allows air to come in through the threading so when you try to pump out the fluid, it just sucks in air instead of the brake fluid. Not sure if that's what you experienced.
    Re: Fixed My Brakes
    I found that the Mityvac works to get fluid to register, after that the pump, crack, close method works best in lieu of a power bleeder.
    Jim, come talk to me when you have to do a brand new master cylinder on a passenger vehicle with ABS. THAT is a load of fun. Hour and a half just to bench bleed the master in my truck....nevermind having to hook up the lines then bleeding the rest of the system. Good times!
    Re: Fixed My Brakes
    billy, this was for my 06 600, not the street bike. and the difference was the calipers. changing a master & lines doesnt take as much time to pressurize as if you opened up the calipers and took the pistons out.
    bergs is right about the mitivac. they're a great tool to get you started, but the old school method is best for finalizing those last few air pockets. picked up a brake line hose from Steet & Comp and bled them in between sessions. the mitivac has that black attachment onto the bleeder, so you can't see if there's air coming out.
    Feb 2006
    Metro West, MA
    Re: Fixed My Brakes
    Gotcha. I could see the calipers giving you an issue. Good luck with the brakes!
    Re: Fixed My Brakes
    For some reason I never have any luck with MityVac's or air powered bleeders, flicking levers and pushing lots of fluid through seems to work for me. I'm going to have to get a tune up on my bleeding techniques from a pro one of these days I guess.
    Uxbridge, MA
    Re: Fixed My Brakes
    I've gone as far as taking the whole system off the bike giving me an issue and hang them upside down and re-bleed them, then once again when installed. Always getting the pistons pushed back in to move the fluid.
    It's quick enough to do and beats messing with them week after week.
    I would think If you need to bleed any system after "x" rides/miles you have air getting in there someplace, They should be air tight systems. Air=Moisture=Bad JuJu.
    I agree mityvac's are good to get it started, hand bleeding is best after that.
    Either way you get it done, glad to hear it is fixed. Now you can build confidence instead of thinking "brakes" all the time. That's gotta suck.
    Re: Fixed My Brakes
    Quote Originally Posted by FireboltEric_MA View Post
    now i'll have to come up with a new excuse why i suck out there
    Re: Fixed My Brakes
    Quote Originally Posted by MotoFreak View Post
    Bill, you got the title wrong, it should be Super Jimmy's Motorcycle Repair Manual.
    Feb 2008
    Las Vegas
    Re: Fixed My Brakes
    Quote Originally Posted by 07BladeRider View Post
    Word, my b. Maybe he can help me with my fork issue, that'll be good for another chapter!
    Carpe Diem
    '10 Yamaha R6-Race-
    Re: Fixed My Brakes
    I'll play a "Jim card" here and ask "Why is this thread even in the Pit Area?" Shouldn't it be in the Bike Maintenance forum?
    Feb 2008
    Las Vegas
    Re: Fixed My Brakes
    Cause Jim's a racer!
    Carpe Diem
    '10 Yamaha R6-Race-
  1. need to get this fixed!
    By Omahastylin16 in forum General Bike Related
    Last Post: 05-06-09, 10:49 PM
  2. Replies: 27
    Last Post: 03-15-09, 03:01 PM
  3. BIKES FIXED
    By Headstrong in forum General Bike Related
    Last Post: 07-03-07, 02:55 PM
