Gotta admit I'm seeing all upside at this point:
125 - philosophically correct
SV - practically correct
636 - militarily correct
motard - ugly pretty gonzo freakshow
What ever you buy, get it already track ready... Anyone who has bought a street bike and "tracked" it will tell you this.. Unless you want to put it back for street duty as well..
Gman
Gerard
Scott is looking over the Grid sheets at LRRS Event#1 & asks me "No 125's racing in 125 Grand Prix Expert race?" I bought my '98 RS125 back in '06 and had a blast racing it for most of the past 5 racing seasons. Last year I chased after the AHRMA Sound of Singles 2-stroke Championship. Had a great chance of winning it until my wife wanted a divorce in July '10. That messed up my head and forgetting to add pre-mix oil to the race fuel leaves disastrous results (lower con-rod bearing self-destructed).
Over the past winter, Kevin Elliott (CCS) agreed to let the 125 GP bikes race in UltraLight SuperBike and LightWeight SuperBike CCS classes. LRRS followed suit and now there are enough classes to race 125 GP bikes in, that it is worth owning one of these. 125GP, UltraLight SuperBike, LW SuperBike, GTL and LW Grand Prix are five classes that you would have fun racing in, once you get bumped from Novice to Amateur. Obviously 125 GP and UltraLight SuperBike should be the most competitive ones to enter with the bike, since you don't have to compete against SV650 or 1000+cc Ducati Air-cooled twins.
As Mike mentioned, the single-cylinder 125cc RS125 is so simple and easy to work on, as long as you have some half-way decent mechanical skills. Guhl thermostat can be added to eliminate the need for tape on radiator. There are several 125 GP bikes usually at the track & most anyone would be glad to help you with the somewhat steep learning curve of this bike. I weigh around 190# & at 5'10" tall appear somewhat overwhelming sitting on my 125. The trick to riding a 125 is carrying speed through the corners. You need to hit your marks & perfect keeping the motor in the powerband to do well on it.
The SV650 is really a lazy man's machine. A great entry-level race bike with enough mid-range torque that forgives what is required to go fast on a 125 GP bike. I bought a used SV650 for my Instructor bike & consider it a decent rain bike for my TZ250 dry track race bike. Hands down, the RS125 is one of the most fun bikes to ride. Even more fun than a Motard bike.
Good to know, thanks.
I really dig the idea of getting good on something with less power, and hopefully staying good on a bike with more power.the trick to riding a 125 is carrying speed through the corners. You need to hit your marks & perfect keeping the motor in the powerband to do well on it.
you don't need (want) to deal with that the first time around.
personally I'm very biased towards twins so I'd strongly recommend an sv for 'turnkey racing' (is there such a thing?). they're everywhere (think cheap parts) and pretty much bulletproof in supersport trim.
if 650 twins don't do it for you then figure out what does, but realize that bigger bikes (600s) will eat tires much faster and smaller bikes (125s) will require a _lot_ more maintenance (a proper (NV/AM) supersport sv should just need an oil change once a year).
in the end get whatever _you_ want and just know what you're getting in to... find an expert that races that kind of bike and talk to them about it.
Scott
I have a 1g sv that is available in Medford. It isn't the prettiest, but it ran well the few times I rode it. It has a pile of good parts on it but needs a little tlc and some bodywork. It has the important stuff done, GMD built forks, penske shock, woodcraft rearsets, and yosh full exhaust, and some other odds and ends. All it would probably need is a battery. It passed tech with no problem the last time I rode it 2 years ago. I will be up their Monday if you want to see it. pm me for more info.
Good luck on your search you can't go wrong with any of the bikes you are thinking about.
Mike Green
LRRS #450 novice
http://www.mikegreensculpture.com
'06 svx550
'04 cr500 af le
'04 525 smr
'02 660 sms
'01 drz 450 sm streetbike
'99 r7
'99 sv650
'86 rg500
Bill Cool --- CRA EX 47, CVMA EX 478 --- 2023 NEMRR GTO Champion, 2020-21 LRRS LWSS Champion --- RSP Racing / TTD / MTAG-Pirelli / Woodcraft / Sportbike Track Gear / Seacoast Sport Cycle \ Bison
simple. if motor internally is stock why do maintenance if you don't need to?
things like motards are a different story, but a sv with an internally stock motor being run by a novice or amateur? it only needs more if you're throwing it into the dirt/rocks and getting gunk in your intake a lot.
heck with a superbike build 700 hawk motor i was doing oil changes once or twice a year - to be completely up-front my transmission took a shit mid-last-season, but wasn't due to oil it was due to 2 seasons + a daytona RoC between rebuilds and what looks a lot like a bad trans
and, of course, this is what I do. you should do whatever you're comfortable with. just sayin unless you're last name is mullin, doucette, gaboreo, greenwood... you're likely wasting time/money.
edit: I should also note that I was only doing about 8 races a year (plus saturday practices and sometimes penguin practice) and that I use fully-synth motul, for comparison.
Scott
Just an FYI. It may not be a bad idea to rent a suit for your first or second trackday. I know that we (Tonys Track Days) have rental suits provided by Moto Market for around $65 a day. It helps save some money but also lets you try on sizing and see whats comfortable. There are usually a few different options too so you could rent one kind and then rent another manufacturer and see the comparison...just a thought if your on a budget.
The start up is expensive, but good gear will last you multiple seasons if cared for properly.
...I may be mistaken but I think you can rent boots as well.
Chris
LRRS Expert #160
Although the leathers are the big-ticket item, I think as long as I show up to the Vanson factory with a chest protector and back protector already fitted up, I should be able to leave with (or order) the Right Suit without too much trouble.
Boots and gloves though...I just have no idea what my hands or feet are supposed to feel like in the prone position with clipons and high rearsets. Will almost certainly rent those for my first school.
Lets see:
- Live in Boston - check.
- Ride V-Strom - check.
- Want to do track days at Loudon - check.
Yes you are overthinking. Get some good gear and get your V-Strom up there! I did my first couple of track days on my V-Strom. I upgraded the suspension with Sonic springs and Intiminators up front and a 3-way Elka in back. I'm pretty heavy so while hitting a peg feeler a little is one thing, hitting the side stand gives the spine a tingle.
Unless you are sure you are going to be doing a lot of track riding or just want a dedicated bike, I wouldn't hesitate to bring the V-Strom up. I rode up with my camping gear, camped at the track, took all the gear off, rode, put the bags back on and rode home. There are some advantages to having a track bike and a truck or trailer, but it's not the same as riding the same bike up and back. Lot of fun either way. This was either my first or second day. Just do eet.
YouTube - DL650 V-Strom Track Day NHMS
The boots and gloves fit the same, it's the helmet that you have to mind. With my Arai Profile, perfect on the V-Strom, I have a hard time seeing up hills and around corners as it's more of an "upright" helmet than a sportbike helmet.
I wear Held Steve gloves and Daytona RoadStar boots and while not as protective as racing gloves and boots they proved sufficient. I'd buy good boots and gloves before I bought another bike. Ordered some Sidis for this season (higher and stiffer) and plan to get some Held Phantom gloves ($$$) as well. Bought a used Vanson suit (Mr StayPuff) and it will have paid for itself compared to renting after one more track day.
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.3.3; en-us; Droid Build/FRG83D) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
Re: arai profile.turn your head a lot moreI race with one with no issues
Scott
Scott
LRRS Am #331
ya I'm also gonna call BS on the Arai profile comment. Get whatever helmet fits right. I wear a size large profile it fits awesome and i've never had any issues. its as much of a sportbike helmet as any other.
betting it either doesn't fit right or your head isn't turned as much as its supposed to be.
www.bostonmoto.com
Ride to live, live to ride
I have a Shoei RF1000 and can see fine. The opening seems to be placed a little higher. It may also be that the Arai is hitting the back protector.
I'm going to a California SuperBike School course May 11-12, so I'll see what they have for current helmets that might be better.
LRRS Am #331
Went to see the RS125 this afternoon. Impressions:
1. Crazy small, and ever crazier light. Kind of like going to the air and space museum and seeing the lunar lander.
2. Nothing on the bike, from head to tail, seems to be more than a few bolts deep. Especially the motor...pop off the tank (5 seconds) and the cylinder head is staring you in the face.
3. Even smaller when you're on it. You're not really even on the bike until you're in the fullest tuck imaginable. Riding it at speed must feel like being squeezed into the front of a torpedo.
4. Don't just pin it to win it; pin it to get anywhere whatsoever. Owner warned "makes basically no power under 9k".
I definitely want it, but not bad enough to blow my budget by ignoring the upcoming motor rebuild. If my offer survives, it'll be because some crazy stars aligned and he kind of wants me to have it. Awesome way to spend an hour on a Sunday though.
