Page 8 of 8 FirstFirst 12345678
Results 176 to 196 of 196
Lt. Wt. twin VS. Middle Wt. I-4???
  1. #176
    Lifer Pittenger5's Avatar
    Austin
    Re: Lt. Wt. twin VS. Middle Wt. I-4???
    Hey DB, what's it like to still be slower than a really old guy?
    Youre just experienced Degsy! Its not a bad thing, dont look at it as OLD, just experienced.
    Zip Tie Alley #505
  2. #177
    dammit - I wanna race an 848
    Me too, That would most likely make me go back to MW.
    Off topic (sort of) I crashed both MW and UL and LW Bikes and never got Hurt on the MW only the little bikes
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
  3. #178
    I have raced just about every class there is at some time or other.
    Coolest - big i4 bikes
    most fun - motaahhhd
    Nov 2007
    Quote Originally Posted by Jonny Rocket View Post
    I say you should race whatever the f@#k you want.
    It will still be one of the coolest things you will ever do.
    Probably the most sensible comment in here.
    Zip-Tie Alley Racing
    LRRS/CCS #103
  5. #180
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Quote Originally Posted by ceo012384 View Post
    next to this one...
    too bad the ceo action figure would be actual size
    Meridinium
    I'm going to try racing the 600 because its what I have in the garage.
    I like the power of it, and its fun to ride. I am sure that at my squid level I'd get that same rush from an sv, which might better suit my age range from what I just read?
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    I haven't raced both at Loudon but I have tossed a 600RR, R6, and 1098 around Loudon a few times
    I haven't ever raced a MW bike competitively but I have put a bone-stock 848 (that I didn't own) within 5.5 seconds of making the AMA FX grid at the hardest track on the AMA circuit, my first time on it.
    Can I have a cookie?
    Race whatever the shit you want. I god damn love riding a big bike but for Loudon you won't catch me racing one anytime soon. When the new track is build thou... hollah!
    Mmm 1098... never forget coming into T5 at Barber 4th gear pinned, banging down 2 shifts into 2nd, backing the rear tire in, hitting the double apex, spinning up the rear on the exit, and then pulling a power wheelie thru the next 2 gears over the crest while the bars are banging lock to lock due to headshake.... GIGGITY!!
    Hey oh yea. In the motard class you get to race Jeff Wood, Shane Narbonne, Mike Martiere, Eric Wood, Brent Lyskawa, JayRoot, and a host of other random TOP DOGS at Loudon. BOOOOOIIIIIIIII!!!!!
    Boston --> San Diego
  8. #183
    Austin
    Hey oh yea. In the motard class you get to race Dollar Bill, and a host of other random TOP DOGS at Loudon.
    Yah, there ya go
    Zip Tie Alley #505
  9. #184
    pete, i havent checked lately but a while ago i was hearing that getting a lot of power out of the FI models was tough because you can only get so much fuel out of the injector. i know people were experimenting with different injectors but havent heard much since. the carb bikes though...you can always put a bigger set of carbs on. theres nothing wrong with the FI bikes per say, just a power thing. i think out of the box the FIs make a few more ponies, but down the HP road the carb bike will win (AFAIK)
  10. #185
    next to this one...
    hi kitt
  11. #186
    If people are getting stuck 'cause of the stock fuel injector choice made by Suzuki, they should step away from the dyno and put their 'tuning' cert down*.
    SOP in this case is to A) Up the pressure on the fuel rail, more pressure == more fuel per squirt, then B) you nailed it, higher flow injectors.
    Ideally you should be getting MORE power out of an FI setup as you can safely run a larger diameter throttle body and still have good fueling at low RPM/flow than you can coax out of a comparable sized carb. That said, I'd be curious to know just how radical a build we're talking about where they're outflowing the stock injector.
    *I kid, I kid!
    Lake Champlain, VT
    *I kid, I kid!
    just my .02 - the stock injectors won't perform much better with higher fuel pressure.
    but - yes, no self proclaimed tuner would say FI is more limiting.
    What's Zook got shoved in there anyways, 3 bar fuel rail and low impedance injector? (I haven't had a chance to fondle a fuelie dirt donk yet.)
    I've raced on:
    Ducati 748 (twin), Daytona 675 (triple), Honda F4 (I-4), Ducati SS800 (Lt. Wt. Twin)...
    Personally, Lt. Wt. Twin or MW Twin were the most fun, but I'm also more comfortable on a twin in general... Part of what I loved about racing the 748 wasn't in the MW class, it was in Supertwins, which is a fantastic class to race in w/ good guys on anything from built SV's to Buells to 1098's.
    Had the best times in that class...
    CCS/LRRS #83
  15. #190
    I am pretty sure as with 90% of us the Bikes Power is not the Limiting factor. (except of course Josh Kurlon where it is definitly the Limiting Factor) My understanding is that The chassis on the First gen are better. Its also my understanding that Its very hard to go from a first gen Chassis to A second gen and Visca Versa that the geomityy is very Very diffrent.
  16. #191
    1/8 of a liter is plenty SilverDragon's Avatar
    Pittsfield, MA
    I'd rather ride a slow bike fast than a fast bike slow.
    amen to that brotha
    Neal Mulcahy
    LRRS/CCS #427 ECK-Racing 2009
    Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Moon Performance | Motorcycles of Manchester | BostonMoto-Pirelli
  17. #192
    *I kid, I kid!
    you can only push so much fuel through an injector before you need a bigger injector. its easier to drink a milkshake with a big Dunkin straw than it is with a Mcd straw. thats simple physics. sure you can put 8000lbs of fuel pressure through a stock SV injector but wouldnt it be better to put in a bigger injector and use 8lbs of press AND still get more fuel?
  18. #193
    Hiram, ME
    "I know a guy who knows a guy who crashed a 600 in his novice race"
    Lifer eboos's Avatar
    Do I get any extra points for riding a slow bike slow?
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Quote Originally Posted by eboos View Post
    You race a motorcycle which gets major points in my book.
  21. #196
    Lots of times, it's easier to just up the pressure. Ever since FI came out, playing with the pressure of the rail has been a standard tuning technique. Plus, with higher pressure you get better atomization. The flow increase is directly proportional to the pressure bump, the only potential gotcha is if you go crazy with the regulator and piss off the fuel pump. You'd have to really crank it up to risk it on a race bike though, the runs times just aren't long enough.
    I'd like to know what people are doing that they're running out of injector timing though, I've seen lots of crazy builds on other bikes, and the only ones that could justify an injector swap were jumping from 80rwhp to mid 130s...
  1. A belated hello from the middle of NH
    By audi in forum Welcome and Intro
    Last Post: 04-11-15, 05:37 PM
  2. middle lane
    Last Post: 06-10-05, 07:48 PM
