So I was watching Closer To the Edge last night, and I saw that they always seem to push the motorcycles out of the pit.
Example here: http://www.youtube.com/watch?feature...wzCP_89s#t=49s
Could anyone explain to me why this is done? I can't seem to find any answers through a normal google search.
2000 Suzuki Bandit 600
1978 Suzuki GS550E (Project)
Most are total loss (meaning they don't hold a charge) so they need to bump start the bikes because they don't have starters.
Thanks, that makes a lot of sense. I'm guessing it's done as a weight saving measure?
Weight savings is the principle, but reducing rotating mass inside the motor (flywheels and stators) to allow the motor to spin up faster and/or make more power is the main idea.
Because I know Graham is lurking.
http://www.nestreetriders.com/forum/...-flywheel.html
I have a total loss system and retain my starter but have no stator.
It all goes to less weight
Think of a chain saw or weed whacker with a pull starter. They just have to push start theirs. . Similar principals can be applied to a bike.
Good read. And by idea in my last post, I guess I meant marketing.
Save the clutch
keep time off the motor.
I thought most bikes at the IOM TT have starters... If you look/listen closely to that video, I'm fairly certain he fires it up with a starter.
If they don't have a starter, they're bump starting it.
If they DO have a starter it's to:
Get them out quicker
And perhaps also to make sure they don't stall out.
The example you showed was Guy Martin. There's no telling why he had has bump started...he could just as well have used a steam engine to drive a roller starter!
Muhammad Ali.
In some cases, the SV650 is a good example, the crank is a weak point, which often fails under a lot of use. Lightening the stator rotor, or removing it altogether (like was done to mine) lightens the lad that is placed on the crank.
So, in this case, it's for durability.
R.I.P. - Reed - 3-23-2008
Matty V you are missed.
LRRS/CCS #76 / RSP Racing / Northern New England Appraisal Services / MTAG Pirelli / Dyno Solutions / Tony's Track Days / MOTUL / Sport Bike Track Gear / Brunetto T-Shirts /
