Results 1 to 25 of 41
OK, Motard guys... Brakes!
    Jun 2005
    Alright... who's running what for brakes?
    What do you like about what you're running?
    What do you dislike?
    My KTM has a 320mm rotor, HH pads, SS lines and stock Brembo caliper/master. Looking to upgrade during the off season.
    Anyone running some sportbike stuff? I know Jeff (HD) has a Brembo MC off of a 996 that seems to work well.
    I'd be interested in hearing about some lower-cost alternatives if they exist, but it seems all the sportbike masters have really big pistons. NOt sure how well that would work with a single-caliper setup.
    And before anyone posts it, yes, I've seen the $149 Braking caliper on Motostrano's clearance site. I dig the price tag, but was looking to do some research first.
    So what are you guys running?
    JACKASS hammadown's Avatar
    Hopkinton, MA
    Re: OK, Motard guys... Brakes!
    Glad you posted this. I was going to ask you about your rotor/caliper as I think we have the same one. Do you have to take the rotor off to get the caliper off? Brian and I couldn't get the cal. off due to clearance. Makes changing front wheels/ pads a pain in the ass.
    Interested to see what people like for calipers up front. Brian mentioned a brembo for $200? *Paging brian jeff*
    And yes that 996 master is the cats anus : Now I need a caliper that comes off easily.
    Zip Tie Alley #237
    Jun 2005
    Yeah the stock Brembo just barely fits past the rim when taking the wheel off, so no need to remove the rotor bolts. I can see how that would REALLY drive you nuts. EDIT, yours is def. different, though... You've got that annodized hard parts joint, I believe.
    Posting Freak Puppet's Avatar
    Oct 2004
    Seattle Area
    I LOVE my brakes.
    I'm running the Brembo Cast 4 pad, this link, second down:
    QTMI/BREMBO/MARCHESINI/SPARCO
    and the 16x18 radial on this page:
    Using the stock SMR rotor. 310 mm wave rotor from Braking, made for KTM.
    When I ordered the caliper, I told them what I was running it on and they shaved the back so it clears the spokes and sent me the proper spacers.
    Brian
    LRRS/CCS EX #881
    WMRRA EX #281
    Hopkinton, MA
    Interesting...guess Ill need a tricky mike lesson on caliper removal
    OFF Topic: I am very glad my new name for you stuck, it has such a ring to it
    Zip Tie Alley #237
    Oct 2004
    Seattle Area
    Those are going to be a bit different from you guys b/c my caliper is radial mount from the factory. I know there are brackets you can convert to a radial caliper though
    Brian
    LRRS/CCS EX #881
    WMRRA EX #281
    Jun 2005
    You got the radial mount fork foot, though, no?
    Wonder if our stanchions are the same and I could buy 'da foot.
    Jun 2005
    ah, but front axle diameter would come into play too... I bet those are different on our bikes.
    hmmmmmm
    Oct 2004
    Seattle Area
    I know the cap on the axle is 27 mm...but I'd have to look up the specific dimensions of the actually axle
    Brian
    LRRS/CCS EX #881
    WMRRA EX #281
    Lifer lrrs313's Avatar
    Asheville, NC
    I've got the same caliper as Puppet with the Hard Parts radial master. The caliper is worth it's weight in gold -- awesome stopping power, no fade. The master, in my opinion, is overpriced. The KTM unit is really nice and works great, but it's a LOT of money. I'd go with the Brembo radial like Puppet if I had to do it again.
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    I have full Motomaster rotor, caliper, SS line, and Magura master. It's the bomb. As you may recall I own Jeff Wood's old RMZ so that's what he spec'ed it with
    Really doesn't get much more powerful than this. I can do 1-finger endo's into T3 all day long.
    Boston --> San Diego
    Jun 2005
    That Magura pumper is pretty trick.
    Lifer Pittenger5's Avatar
    Austin
    Alex what do I need to put on my bike to make me faster than you? (aside from a faster rider)
    Zip Tie Alley #505
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Seat-time homie! That's the trick
    (LeoVince X3 pipe wouldn't be a bad start thou..)
    I've got the complete MotoMaster race kit on mine.
    12mm radial master, stainless line, 320mm rotor, caliper and relocator bracket..oh yeah, and the brake pads.
    I've only ridden the bike at one trackday and the brake feel was awesome IMO. I had almost the same set up on my 04 YZ450 less the radial master, I used the stock master for the bike...and had almost no feel. It stopped awesome but it was like a light switch
    Meriden, Ct
    Wow. Just fuckin' wow!
    You know nobody likes you, right?
    Dec 2003
    Ma
    I think racetech makes fork bottoms that also have adjustable offset inserts along with the radial mount setup.
    I run a beringer 6 piston setup including master, it could stop a truck on a dime with a pinky pull.
    Dec 2003
    Ma
    send me your e-mail.
    Jun 2005
    hmmmmmm
    So, after a little digging it looks like the KTM fork foot with the radial mount (like Brian's 560smr) will fit on the 02 520SX (SX only though, the EXC/MXC had 43mm tubes). The axle diameters are different (20 vs 26mm) but that may be a relatively easy fix with an adapter. That'll open up some bracketless brake options fo sho.
    There's also some aftermarket stuff that Racetech is importing (thanks for that link, Jay), but they didn't really have all the details on price/availability yet. I may give them another ring before I order the SMR part.
    Oct 2004
    Seattle Area
    Hey mike, talk to your dealer...check part number SXS03540400. I think it's the part number for a 20 to 26 mm adapter. I know it's out there (we used to carry one) and you should be able to get it from a KTM dealer for short $$
    Brian
    LRRS/CCS EX #881
    WMRRA EX #281
    Jun 2005
    Quote Originally Posted by Puppet View Post
    Thanks Bud.
    That does seem like the right part number.
    If I brought one home my lathe wouldn't speak to me for a week.
    Austin
    I love the spin doctors!
    Zip Tie Alley #505
    Oh shit I need to come by to get those tires Put on.
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Jun 2005
    Yeah, I looked at those the other day and had to think for a minute... whothefuck?
    Anytime, mang.
    I found the Magura 195 Radial master For under 250.00 No billet but really nice.
    http://www.spieglerusa.com/cfm/mc_ca.cfm
  1. For Sale - Parts & Tools | 02 CRF450 Motard Parts: Wheels, slipper clutch, Berginer brakes, lots more.
    By JettaJayGLS in forum For Sale
    Last Post: 08-27-15, 10:34 PM
  2. Qwestion For Motard Guys
    By lrrs428 in forum General Bike Related
    Last Post: 04-04-11, 09:57 PM
  3. Motard guys, gearing..?
    By MysteriousR1 in forum Bike Maintenance
    Last Post: 06-21-09, 08:33 PM
  4. Motard Guys Damper?
    By BLACK SQUIRREL in forum Pit Area
    Last Post: 03-01-09, 09:15 PM
  5. Motard Guys.......It's a long way to WFO!!
    By KB in forum General Bike Related
    Last Post: 10-31-06, 09:48 PM
