Results 1 to 21 of 21
Question for the 600 guys.
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    What kind of drive ratio are you using for NHIS?
    I have 2.81 stock, but just bought the stuff for a 3.13 and 2.94 set-up... Thinking of going to the 3.13, and if I need more gear, step it back down.
    Just bought a 520 set-up, with a 15,16, and 47. I do have a 45T rear, but it's on my rain wheel, and it's a little work, so I'd like to use the new 47.
    I was having a hard time pulling out of 12, it seemed like I was getting walked a little...
    15 47 = 3.13
    15 45 = 3.00
    16 47 = 2.94
    16 45 = 2.81
    P.S. I understand each bike will be different, but just curious...
    Posting Freak senecak19's Avatar
    Massachusetts
    I've run:
    16 / 45
    16 / 47
    15 / 45
    15 / 47 (where I'm at now)
    I considered switching to 15 / 46 because I was going through all my gears on the home stretch, however, bikes are still pulling on me coming out of most corners so the 46 is out of the question for me.
    Lifer s a x m a n's Avatar
    Mar 2003
    Lee, MA
    i have found that for me, its less about gearing and more about carrying enough speed through the corner and actually getting on the gas sooner and more aggressively. I have done the gearing change, but never saw much improvement. You are only talking 500-1000 RPM difference for some of the ratios.
    I am -1 front/+2 rear for reference though ... i forget where that puts me for a ratio, but it works out well, but I still need to be on the throttle harder
    Worcester, MA
    Quote Originally Posted by s a x m a n View Post
    +1
    carrying more corner speed is going to make a bigger difference until you are looking for tenths of seconds.
    LRRS EX #165 (formerly)
    Most guys with the 03 GSXR were running 15/49. I've even seen a few 15/50 setups. You definately don't want anything less than 15/47 for loudon.
    Lake Champlain, VT
    Quote Originally Posted by mmracer37 View Post
    thanks!
    I feel like an icy hot stunta with this 47 going on haha... guess the crest before 6 and the drive up to 8 will just be that much harder to stay down for.
    Mar 2003
    Lee, MA
    i never got the wheel off the ground until this year going over 5 .. even then it wasn't every time. It got light (7 to 8 for sure), but finally started to get the front wheel off the ground over 5 (now just trying to hang over the front to keep it down). Didn't change gearing because it was all in my drive up 4 and being on the gas hard.
    I'm not trying to say don't change gearing, because yeah, stock gearing is not a good solution for loudon, but don't expect the change to be as drastic as you think it might be (like I thought) ... its still all about being able to put the power down as fast as possible.
    again, just commenting from my experience last year
    Feb 2004
    Bellingham, MA
    Most inline 4's will run 1 tooth smaller in the front and 2 teeth bigger in the back. Your stock gearing was 16/45. Run a 15/46 or 47 and make it work. DO NOT GEAR IT SHORTER!!!!!! You will get most if not all of 5th at the 4 board going into T1. If not, then I'll show you how......
    Mar 2003
    Lee, MA
    again, peter proves my point that I still suck and its less about having the right gearing and getting on the damn gas (i..e "don't be a pussy" - peter kates)
    May 2005
    Bernardston, MA
    If I remember correctly, I seem to recall PK talking to Jamie maybe at a track day last year, and it was something along the lines of "on corner exit, whack the throttle open till the rear starts to slide out, THEN back off."
    Mar 2003
    Lee, MA
    yeah, i think the next weekend I was like "uh .. pete my bike highsided me twice ... i don't think i'm doing something right"
    hahahah
    but in all seriousness, one of the best pieces of advice I got from PK was how you have to make sure you have your turning done before you wack the throttle, because if you increase throttle while increasing lean angle you end up with less traction. This really helped me out, and made me setup for corners better along with understanding the physics of what goes on and one of the reason I was crashing more than I wanted to in races.
    I have not crashed yet (knock on wood) after that discussion. If you have the bike already turned and you get on the throttle good enough to brake rear traction it will just modulate back and forth (if you hold steady on the gas) instead of kicking out. I have experienced this a couple times going up turn 4.
    Feb 2004
    Bellingham, MA
    Quote Originally Posted by JeffL View Post
    Not exactly....... I never said back off.
    Feb 2004
    Bellingham, MA
    If you gear the bike too short, you will never be able to get your roll speed up. Which believe it or not reduces the chances of a high side.
    True The faster the rear is spinnng(rolling) the less the chance of highside IE the less the diffrence between the speeds.
    Like a car can do a nasty burnout at 5MPH may not even chirp them at 40 MPH.
    If I have a problem with my bikes power or performance I aways First look to myself and what I can do as the rider to fix this. I am the slowest part of the equation. providing my bike is operating properly. 99.9 % of the time its me thats holding it up
    My .002
    Mar 2003
    Lee, MA
    Quote Originally Posted by Mongoose441 View Post
    My .002
    werd!
    Lake Champlain, VT
    so you guys think in spite of nearly everyone running a higher gear ratio, I should stfu and run stock gears?
    like i said in my other thread, I have pleanty to learn and improve on, but that gearing just isn't getting me out of the turns like i'm used to on my liter bike.
    No Not saying that You already got this stuff, Use it. My bike Came geared for loudon. As long as you have good maintained racing suspension. I would not go nuts with mods......... yet. the best investment is not Mods but tracktime.
    My .02
    Lake Champlain, VT
    My .02
    a 520 conversion with the right gearing for the track isn't really an unecessary mod... but I am planning on getting seat time as work and $ allow.
    It won't be too easy to get full track days in, but i should be able to make a few friday practices.
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    You should 100% gear your bike correctly for the track based on what the good guys are running (go see Mike's post).
    Once it's geared right, then you can work on the Rider Problems.
    Boston --> San Diego
    ....... Nazo's Avatar
    Jul 2004
    I just changed my gearing now I'm running a 15/48 on a Honda 600RR.
    This gearing I like better becasuse it allows me to be in 3rd and 4th through most of the track.
    I'm going through turn 12 onto the straight now in 3rd gear and hitting 5th a lot sooner than before with a better drive into 1.
    I ran all last year with a 15/45, I like the new gearing a lot more.
    Chris
    LRRS Expert #160
    KB KB's Avatar
    Manchester NH
    Quote Originally Posted by Nazo View Post
    Your current gearing send you sliding in the bowl. I would go back to what you had last year!!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
  1. Question for the touring guys here
    By soofle616 in forum General Bike Related
    Last Post: 03-16-09, 01:31 PM
  2. Question for the ducati/triumph guys
    Last Post: 12-07-08, 11:56 AM
  3. gsxr guys quick question
    By Mystic in forum General Bike Related
    Last Post: 05-09-07, 11:30 PM
