Page 1 of 3 123 LastLast
Results 1 to 25 of 55
PTwins
    Posting Freak 6 Fingered Man's Avatar
    Feb 2009
    Exeter NH
    PTwins
    Ok, so Dan finally bought his ex500. It's a nice bike, despite the fact that I laid it down in a parking lot playing racer on the way home (privately owned lot, Dan knows the owner) but that leads to a question: Do you guys race on those seats? Can we make a fiberglass seat and put a pad on it or do you have to keep that stock seat? Also that handle attached to the sub frame behind the seat, can that go? Are rearsets to much to ask? GP Shift? What can we do tho this thing while keeping it in the class? It has aftermarket suspension so I would assume there is some flexibility with the bikes?
    I am also probably getting one of these this week so any info would be great because I'm going to disassemble and build it frame up since it's not quite the condition of Dans.
    Lifer Pittenger5's Avatar
    Austin
    Re: PTwins
    Its all in the rulebook. Everyone races on the stock seats, dunno if they're required, I believe they are. Suspension changes are allowed, but must keep stock forks and mounting points. Rearsets are allowed, whether they're necessary is a personal thing. The handle can go. For GP shift you need to get a different shifter, something like a 2002 ZX6s.
    Zip Tie Alley #505
    Just Registered Doc's Avatar
    Jericho, VT
    Re: PTwins
    Seat and handle stay IIRC. Rearsets are ok.
    Rulebook here http://www.lrrsracing.com/2008/2008_RULES_2.pdf
    Feb 2009
    Exeter NH
    Re: PTwins
    Good to know, that handle can be pretty useful.
    Re: PTwins
    why would the seat have to stay?
    i think people keep the seat is because its shitty mcbikefest
    Re: PTwins
    As per the rules...
    Production Rules:
    8.3 Fairings supplied as standard equipment are allowed. Removal of fairings is permitted; however, a headlight shell must be refitted.
    8.11 Seat padding may be partially removed and/or replaced with different padding.
    8.19 Items to be removed in the interest of safety are: turn signals, rear view mirrors, side and center stands, license plate, and anything else as may be deemed dangerous by the scrutineer.
    So, based on that, my read is that you can remove factory plastic if you want, but you can't replace with alternate bodywork. You can however mount the stock seat pan with a layer of neoprene as a race seat.
    Feb 2009
    Lost in constant migration
    Re: PTwins
    As per the rules...
    so a custom 1 up seat like the 6 fingered man made for his CB would be ok, just no fiberglass cowling behind it? Cool...
    Lifer s a x m a n's Avatar
    Mar 2003
    Lee, MA
    Re: PTwins
    you might want to keep the padded seat since it takes 3.5 hours to make it down the front straight on an ex500
    Lifer daviid's Avatar
    Oct 2004
    Plantsville, CT
    Re: PTwins
    Quote Originally Posted by s a x m a n View Post
    as i recall from my experience
    and i believe airtech makes a approved body work.
    -Benjamin Franklin
    Re: PTwins
    Quote Originally Posted by daviid View Post
    Approved by who? It's not in the rules... : )
    Re: PTwins
    ive seen aftermarket body work run out there. how can they tell you that you have to run OEM bodywork? that ridiculous.
    Re: PTwins
    Hey, I didn't write the rules. They also say you have to run OEM exhaust, which on an EX == constant replacements due to dragging. As far as all the race bodywork out there, that's likely 'cause no one has raised a protest about it.
    Re: PTwins
    the exhaust is a performance enhancement...bodywork is not. if you look around i think youll see that there are more bikes without OEM bodywork than with
    Austin
    Re: PTwins
    Kurlon is what we call a "rules stickler". And aftermarket bodywork is never approved nor disallowed in the rule book.
    Zip Tie Alley #505
    Re: PTwins
    Yes, yes I am.
    Looking at the rules again, I think aftermarket that matches OEM is OK, but anything that adds fairings (lowers if the bike didn't have them?) or changes the shape/look, like say a race tail is out. I could update my bike with GS500F bodywork, but not Airtech's Ttian kit for example, as the titan kit's bodywork is distinctly different from OEM.
    Austin
    Re: PTwins
    Yes, yes I am.
    Nothings really spelled out.
    And if someone tried to protest someone in PTwins over fairings, they'd probably be laughed out of LRRS.
    Zip Tie Alley #505
    Re: PTwins
    After raising my ride height, per "order" of the EX Mafia, I had zero issues dragging my exhaust... even had enough clearance to run a belly pan, which made Oxx jizz in his pants, I'm sure
    I also had a stock seat, but all aftermarket bodywork. Airtech makes aftermarket race glass, including a rear seat cowl that's one big piece that slips over the stock seat & subframe.
    You can run the Gen 2 bodywork on a Gen 1 if you prefer... To my knowledge you just have to swap out the upper fairing stay & gauges.
    Looked like this:
    http://www.airtech-streamlining.com/...5001987-93.htm
    http://www.airtech-streamlining.com/...5001994-06.htm
    Re: PTwins
    Airtech makes a similar solo seat cowel for the GS, seemed very flimsy in how it attatches though. I can deal with number plates and having to cut one ziptie to pull the seat.
    Re: PTwins
    replacing the seat with a fiberglas one improves feedback a lot, as do rearsets. Everything on a racebike should be as rigid as bearable IMHO. Mushy seats and floppy pegs will hinder connection to the bike and tires.
    Re: PTwins
    ridiculous...the same rules you are trying to stick with also say that you have to have a belly pan
    i believe the rules in that area were meant to prevent bonneville streamlining
    who cares. youre a NV running a GS that is severly down on power in a class that is over run with EXs. put GSXR1k bodywork on it and an aftermarket exhaust and i still doubt anyone will care
    Re: PTwins
    Good news, I have a belly pan for this year. That said:
    Quote Originally Posted by 2008 LRRS Rules
    7.17 F. All production twin motorcycles are exempt from the catch pan rule
    So rail at the motards and any other 4 strokers running sans belly pans, but the ptwingles are exempt.
    Quote Originally Posted by SVRACER01
    Why don't I just roll up to the grid on a works Supermono with a spare top end stowed in a backpack for that matter?
    Re: PTwins
    So if I swap in corbin seat foam* I'll be styling? : )
    * Corbin seat foam is made from only the finest fossilized sea sponges and dead corral cutings.
    Re: PTwins
    the PT belly pan rule is new.
    Austin
    Re: PTwins
    See Oxx you CAN make a difference when you have your mind set on something!
    Zip Tie Alley #505
    Re: PTwins
    Nice, Dollah!
    Oxx, why can't you be more proactive in your pursuit for belly pan rules?
  1. PTwins dying
    By Kurlon in forum Pit Area
    Last Post: 05-10-13, 07:10 AM
  2. Loudon Classic - Novice PTwins Vid
    Last Post: 06-26-09, 12:52 PM
  3. The Ptwins thread.
    By Doc in forum Pit Area
    Last Post: 04-14-09, 07:35 PM
  4. PTwins peoples
    Last Post: 08-14-08, 09:49 PM
  5. Replies: 161
    Last Post: 10-16-07, 06:29 PM
