Page 2 of 2 FirstFirst 12
Results 26 to 39 of 39
Race chains & sprockets.
    Infected Slyder's Avatar
    Concord, NH
    Re: Race chains & sprockets.
    After catching heat over ordering a 520 kit for a litre bike, I have some other info for ya
    DID ERV3 = 8650 lbs tensile
    EK MVXZ = 9300 lbs
    That's for 520 pitch, My 520 chain is stronger than DID's 530 ERV. Slick. The DID is the lighter chain though. Thiner side plates = lighter weight but clearly not the strongest.
    In your application, you'll probably want the lighter chain.
    As for sprockets...I've used vortex without a problem, even though the rear aluminum isn't hard anodized. I had no problems with them on my gixxer 750 though. Vortex prices aren't crazy either. Sunstar are stamped. Not good. Not pretty when they explode either. Never used Renthal, but have never heard anything bad about them.
    Oh yea, the backside of the EK chain box also says to clean the chain with a biodegradable degreaser, then to use kero if necessary.
    Quote Originally Posted by Slyder27 View Post
    I've been looking at converting my GS from 520 to 428... newer chains are a crapload tougher than they used to be.
    Oct 2005
    Wrentham MA
    EK MVXZ = 9300 lbs
    My 520 chain is stronger than DID's 530 ERV. Slick. The DID is the lighter chain though. Thiner side plates = lighter weight but clearly not the strongest..
    exactyl that's why EVR3 is not good for liter bikes.
    maybe I was not all that clear - it's the stongest/weigh ratio chain.... my comments were aimed at a)knowing it was for a SV and b) looking for power savings of going non O ring.... not necessary going to gain anything
    BTW the evr3 has 15% greater fatigue strenght than evr2 - make sure its a EVR3, there are still EVR2 and even EVR1 chains out there.
    Graham
    KB KB's Avatar
    Manchester NH
    Quote Originally Posted by zx1012r View Post
    Back when I was crewing for my friend in the 80's we used to get an o-ring chain and cut all the o-rings out. That seriously took like an hour to do. We also used to shave the wheel bearing seals, remove any pre-sealed bearing seals, make light "springs" to hold the brake pads off the rotors a little, and all sorts of silly things.
    It really was noticeable on the 883 though!
    Are you fuckin serious???
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Concord, NH
    Quote Originally Posted by xsiliconkid View Post
    Which is why I bought the EK MVXZ
    I thought I had a scale here, I was going to weigh the chain (uncut, 120 links) and then try to get someone to weigh an uncut ERV to compare to. I know the DID is lighter, but this thread got me curious. Unfortunately, the scale I found was broken.
    Oct 2005
    Wrentham MA
    on Oring chains?
    maybe there is something else in WD40 that's not liked by the o/x rings - I know they don't like it..
    In the sake of correctness
    MY BAD, Turns out there is no Kero in WD40.
    It does has a significant amount of petroleum, creating a penetrating fluid primary aimed at Water Displacement, hence the WD..... and the 40.......
    http://en.wikipedia.org/wiki/WD-40
    Given the make up - my point stands - it may start to dissolve O ring material before the light machine oil does any good...
    Graham
    Worcester, MA
    wd-40..... no good for o-rings
    kero.... recommended by a lot of companies on the chain care instructions (but not all)
    LRRS EX #165 (formerly)
    Nov 2003
    New Milford, CT.
    Absolutely! It seems like piddly stuff now but it was under the premise of every little thing you could do might help.
    Now the every little thing you can do is stuff like trick fork internals, GMD setup, Dyno's for jetting, ceramic bearings, 0 weight engine oil, lightened rotors and wheels, looser crank bearing tolerances, etc. etc. etc!
    The biggest thing you could do back then to improve your times was to not eat a Bryar burger before a race.
    Mark
    CCS LRRS #454
    Nov 2007
    I have driven sprockets and a DID 520ERV3. Both are great stuff and I got a good deal on the whole kit from MotoMummy
    As for cleaning, kerosene is the best cleaner... the only thing that the manufacturers do not recommend is leaving the chain soaking in it for more than 30 minutes.
    Zip-Tie Alley Racing
    LRRS/CCS #103
    OOF! Did some searching & found the DID ERV3 chain is up around 130 bucks.
    welllll alright... Guess I'll pony up since I'm a big balla expert now & shit.... or something
    Worcester, MA
    theres going to be some good mid-pack LW racing this year!
    Quote Originally Posted by BMFR6 View Post
    For added "bling" I spent the extra 4 bucks & got a black sprocket... should set off the gold chain nicely
    Old and Slow Sheppo's Avatar
    Westford, Ma
    It'll match your shiny black tank
    Posted by Jane in BoxChat
    Yup!
  1. Wanted - Parts & Tools | Used Chains
    By jasnmar in forum Wanted
    Last Post: 08-10-17, 02:26 PM
  2. For Sale - Parts & Tools | Gsxr and r6 sprockets, 2 pingel wheel chocks, bmc race filter
    By jamotech741 in forum For Sale
    Last Post: 05-27-17, 02:16 PM
  3. Product | how are DID VX chains?
    By breakdirt916 in forum Business & Product Reviews
    Last Post: 05-20-14, 05:04 PM
  4. Educate me on Chains
    By rsw81 in forum Bike Maintenance
    Last Post: 11-18-13, 11:02 PM
