Re: How do I select the correct fork springs??
Is your static sag about 1/4 to 1/3 travel ?
I forget the actual measurement, but rest assured both front and rear have been set properly for my weight, for racing and for Loudon. Set by a Ducati master tech who takes special interest in suspension geometry and also is a Fishtail Riding School instructor and owns and rides a 1098 and 848.
I've added a factory issue Ohlins rear shock from an S model 1098 and an adjustable rear ride height rod. The front is all stock parts, additional fork oil added, fork tube flush with the stock triples.
The 30mm offset triples will make turn in much less effort and allow the bike to keep the chosen line exiting corners under throttle, which is the 848/1098/1198's weak spot. The Ohlins cartridges with correct spring rate will allow me to have more control in heavy braking zones and absorb the craters at Loudon without upsetting the chassis so much.
Next year a linear rear link will produce less squat under acceleration and the upgraded TTX Ohlins shock will work in concert with the rear link, whereas the factory S model Ohlins I have now is not much better than a factory Showa rear shock made for 2up riding.....
Quote:
Originally Posted by
jwm2k3
So I have an opportunity to buy Ohlins 25mm cartridges. The seller says he has every spring made and will give me whatever spring I need.
This will be for racing only, primarily at LRRS, I weigh 170-175 without gear. Which spring set do I tell him to ship to me???
FWIW - Markbuilt switched out my Ohlins springs for free at NJMP and told me it is something Ohlins requires them to do as part of the trackside support deal.
Takes about 5 minutes, I'd check with PK and see if there's a charge to get your Ohlins resprung.
Guess you do learn something new everyday. Since when did Starbucks open up at the track!?
makct04
What does this mean?
John, I can chime in here.
Mine came with 0.95 springs and I weigh 200 without gear.
I had to replace both forks with 1.0 springs.
Maybe you could get a 0.95 and 1.0 on each, so you'll get a 0.975 rate.
Either way, I have two 0.95 springs for 25mm cartridges in the garage if you need to swap and try them. It's easy to swap springs.
jwm2k3
Ducati's + Starbucks
makct04
:scratchhead:
Jim
Thanks Jimmy! The seller is sending me .95's so I'm hoping they will be sufficient. If I need to goto 1.0's I'll buy the pizza and watch you work lol....
Call Jon at Advanced Traction he'll point you in the right direction
FWIW I run .90 @150lbs
Edit Just finished reading, you already pulled the trigger
jwm2k3
You don't want to change both springs at once. If you need a different rate, you do one fork at a time. So you may only need to buy one 1.0 spring.
MFChop
That sounds super fucking soft man.
csmutty
+1
I had .90's in the 650 w/ zx6r front end as stock and I thought they were too soft. Shrug..... I guess everyone rides a little differently.
Jim
This I did not know. Looks like I'll be reading up on fork springs while I sit here on overitme....
