Results 1 to 25 of 29
Stock suspension limits (per experience)
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    If you can afford good suspension, get it... there's a reason everyone says this is their favorite and most important mod to their bike. I'm just curious as to what people were running on stock suspension & rider weight.
    Kitt - 1:18's / GSXR / 190 lbs
    Oxx - 1:19's / SV / ????
    Ryan - 1:16's / R6s / ???
    (cut and paste)
    Re: Stock suspension limits (per experience)
    Clayton - 1:24.1/ EX500 / 130 lbs
    2016 BMW S1000XR
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    Ryan - 1:16's / R6s / 180 lbs
    I'm all for Novices and even slower AM's just going with the "run whatcha brung" mentality. I did it and I was fine for the most part... it just moved around a bunch under me. I'm not gunna say there weren't a couple crashes that may not have happened had I had better suspension though. Any novice racer will be fine on stock, once you start working down your times the problems will become more apparent and you can fix it then.
    T10 was a killer haha
    Lifer Pittenger5's Avatar
    Austin
    Does PTwins count?
    1:29s/EX500/145 pounds
    (Note, very early in my riding career, so that played a little to do with times, but I upgrading due to bottoming out in 9, and a couple other places now and again)
    Zip Tie Alley #505
    Dec 2003
    Ma
    Chris (teach) Mcneil was 15's on stock ZX6 suspension about 175lbs
    Think Eric Sampson was 16's or 17s on stock 600RR about 200lbs
    17's/KTM560/150lbs
    Mike 37
    Lake Champlain, VT
    Quote Originally Posted by mmracer37 View Post
    17's/KTM560/150lbs
    really mike? Do KTM SM's come with suspension better suited for road stuff than KTM dirties, or the big 4 mx bikes?
    17's/KTM560/150lbs
    We gotta talk
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Lifer Ken C's Avatar
    Sep 2001
    Western MA
    Ken- 1:22.8 / Stock MZ / 150 lbs
    Dec 2003
    Ma
    Ox 19's on stock SV suspension? Suuuure.
    I guess I'm a snob. I never really rode on stock suspension. OK, well, my first ptwins bucket was stock, I blew it up before I was much faster than 1:29.
    I have done some laps on a stock new gen R6 that I thought was good enough to race competitively in the expert field for a light rider.
    I really like riding Jamie's RR which is very far from stock. I don't llike a bike to transition a lot of weight in the corners, so stock won't usually cut it.
    Worcester, MA
    guess i'm in the same boat as paul. never really rode stock suspension aroun the track with the exception of my first time on the track ever, and that was on my r6.
    LRRS EX #165 (formerly)
    From my research, the SMRs have higher spring rates stock, front and rear, slightly longer travel than the enduro versions, and increased trail up front by using non leading axle fork lugs compared to the dirt versions.
    just checked my NV times, best i could find i think was a 22.0. i may have pulled a better time somewhere but i didnt dig that deep.
    Just outta curiosity, where did you get that information?????
    Every set I know of has a leading axle from the factory.
    Mike 37
    My KTM had stock WP forks and shock. Nothing spectacular about them. They are definitely DIRT bike forks.
    Mike 37
    Lake Champlain, VT
    I am picking up a yzf450 with no intentions of being competitive on it... probably not racing it. The rider has put stiffer front and rear springs in the bike (how much stiffer you ask? no idea what the rates are).
    I'm more than happy to run it stock, are there any gross shortcomings on the '06 YZF's that you could warn me about?
    A couple different KTM forums had threads discussing what was required to setup an SMR/SMC for dirt duty, which prompted a discussion of the differences between them and the dirt targeted Katooms. I've been doing a mad scramble to read up on them, really doesn't seem to be that much info out there so I've had to resort to gleaning info from forums, as dubious as that can be.
    Doing a lil quick google image searching, I can see the 690 SMC has non-leading axle forks, looks like the SMRs do run leading axle fronts.
    See what I get for reading forums!
    While we're vetting forum suggestions, the other tidbit I came across was the use of clamps from the 125/250 in place of the 450/520/560 clamp set to reduce offset on the cheap?
    Lake Champlain, VT
    on the cheap, eh? I've seen a guy with the "leading axle", behind the fork... must have swapped forks in the triples and spun em around... it looked super weird, and I was looking around for his "gyro" off of his GT performer.
    I've seen guys do that on minis... never a full sized bike... A couple guys doing 'Mono-GP' builds run their clamps backwards.
    =Kurlon;683473 the other tidbit I came across was the use of clamps from the 125/250 in place of the 450/520/560 clamp set to reduce offset on the cheap?
    Yep 14 mm as opposed to 18/20
    cheap and works great
    Austin
    Whered you get the number plates
    Zip Tie Alley #505
    A buddy has a deal with DeCal works, Got em cheaper then Lamb chops
    While we're discussing Katooms and stock suspensions, I assume a stock SMR setup will work with a 130lb sack of wet noodles piloting it at a novice pace?
    Quote Originally Posted by BLACK SQUIRREL View Post
    On the cheap.....hmmmmm
    14 ain't enuff!!!!!!!!!
    you need 8's
    Mike 37
  1. limits of adhesion?
    By Svenny in forum General Bike Related
    Last Post: 07-21-12, 09:39 PM
  2. Suspension setup for stock 05gsxr600
    By patrick #668 in forum Bike Maintenance
    Last Post: 07-29-10, 05:27 PM
  3. stock suspension DIVES into turns?
    By Bandit12k in forum General Bike Related
    Last Post: 05-04-10, 03:14 PM
  4. Experience with GP Suspension?
    By Hauptman in forum General Bike Related
    Last Post: 08-08-08, 09:54 AM
