Hey guys,
Yesterday at NHMS I was out during one of the wet races and my motor lost any power it had. Limped it into the pits... I've found some info online about a clogged drain for the front cylinder. Is there a remedy for this once I clean out the drain? Any sort of... shield?
Thanks!
642
Clean out drain and replace the plug cap... be sure the seal is in place the best it can be. Plug caps seem to be a pretty regular failure in the rain. I tried to have a spare for Sam's SV
X2 drain hole and new cap problem solved
thanks guys!
642
Ah, the infamous SV325.
Gotta keep yer drain hole clean!![]()
i had that happen once. i think pete passed me and gave me a wtf look
problem went away when i installed a fender
edit: just realized you said 2nd gen, didnt those have a plastic flap that covered the front spark plug?
CCS single cylinder blind spot gets you into just about every class other than anything Supersport, Supertwins, or Formula 300. You can run Ultralight 300 but your points will not count for the ROC in Daytona as you'd exceed the 310cc limit on singles in Ultralight Thunderbike.
