Results 1 to 14 of 14
06 R6r Sprocket torque
    Senior Member Slowpoke387's Avatar
    Enfield, CT
    Does everyone actually torque their rear sprockets to 72 ft. lbs.? This seems really excessive to me. I've been trying to stick to that spec. all season, but in the process I've actually stripped a couple of studs right out of the cush drive. My mechanic swears up and down that the amount of torque needed is far less because the nuts are lock nuts anyway, and that 72 ft. lbs. is ridiculous. What does anyone think?
    LRRS #387
    Foxboro, MA
    Re: 06 R6r Sprocket torque
    overkill
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    Enfield, CT
    Exactly what I have been thinking all season. Wanted to keep it around 50 but don't want to kill myself if for some reason someone on here did that and said there was a good reason for the overkill torque.
    LRRS #387
    I just Zap it with the impact gun and Never had an issue....
    Foxboro, MA
    tourque wrench? overrated
    puhahaha
    2006 Yamaha R6
    now paging CEO....
    Lifer union's Avatar
    Blackstone, MA
    I just tightened mine down good. No need for a torque wrench.
    James
    Derry NH
    Yes this is a known issue with the R6, tourque scec is way high for the rear sprocket. You will be fine with 50-60lbf. And if any of the studs are damaged, replace them as soon as possible.
    Enfield, CT
    Quote Originally Posted by Eric Baker View Post
    Yes this is a known issue with the R6.
    That seems like it would be the case. If you actually try to torque them to spec, you can just tell it's ridiculous overkill. What's funny is whenever I remove pretty much any other nut on this bike that was installed by the factory, they all seem like weren't tight enough to begin with. They almost fall off. Really inconsistent.
    LRRS #387
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Quote Originally Posted by DBKromz View Post
    now paging CEO....
    CEO has everything to factory spec to the 3rd decimal.
    Lifer DuncanMoto's Avatar
    And he's pretty fast isn't he?
    Quote Originally Posted by DuncanMoto View Post
    And he's pretty short isn't he?
    and ugly
    Dec 2005
    Near The Dragon
    Quote Originally Posted by Slowpoke387 View Post
    it comes down to an issue of stud size, grade, thread pitch and diameter.
    and yeah, 72 ftlbs sounds like more than the stud could handle
    maybe its supposed to be 72 NM? and misprinted?
    Get out while you can
    Find your own path
    Winter Test SAB's Avatar
    It's a known misprint in the 04-6 R1 service manual as well. It lists 72ftlbs when in fact it should be 28ftlbs.
    I would guess but would not assume that it is the same for the R6.
  1. Torque Wrenches...
    Last Post: 01-10-11, 07:58 PM
  2. EX500 front sprocket torque spec
    By wylee in forum General Bike Related
    Last Post: 04-14-07, 02:28 PM
