Results 1 to 11 of 11
why would 1 carb. read higher vacum???
    "Offspring" wastedincome420's Avatar
    Hickvile USA
    Exclamation why would 1 carb. read higher vacum???
    Why would 1 carb. read much higher then the other 3 carbs on a "carb sync" tool????
    I have out on the adjuster to the point it fell out, BUT it STILL reads much higher then all the others ????
    PLease help!!!!!!!!!!!!!!!!!
    Honda (RC26) VFR700
    "hey Randy, do a wheelie!!"
    vacume leak?
    aka Johnny Valve Stem need4speed's Avatar
    Aug 2002
    Brookfield,CT
    pinched or kinked vacuum line
    John
    LRRS\CCS #714
    2004 Duc 620 monster racebike
    89 EX500 racebike - sold
    98 Superhawk 996
    "To repeat what others have said, requires education; to challenge it, requires brains".
    Walpole
    Low compression ?
    2018 Harley Road Glide
    2000 Ducati 900ss
    2003 Harley Softail Deuce
    not many vacuum lines... and logic tells me it's unlikely a vacuum leak, more likely a plugged vacuum line... maybe a passage inside the carb
    doesn't have to be a vacume line cracked intake boot, loose clamp, cracked o-ring in air/fuel screw, bad seal in the carb tool itself... there are tons of places air can leak in
    problem fixed... discovered slightly tweaked adjuster screw bracket
    Northshore/Beverly, MA
    It would read LOWER if you had a vacuum leak.....
    Higher means throttle plate/slide is closed more than the others
    Junior Member SV1KScott's Avatar
    Beverly MA
    Well that just sucks
    I thought I would come out of hiding.
    Scott B.
    03 SV1000S
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    hey how that sv
    www.bostonmoto.com
    Forum Rules
    Beverly MA
    It's a fun ride.
    5 page spread in August Cycle World about it, "Forgotten Twin"
    I hate it with the lower fairing, looks like a new dress on the old whore and it's heavier and slower with it. Go figure.
    Scott B.
    03 SV1000S
  1. Wanted - Other | PC Graphics card 2GB or higher
    By Scottg22 in forum Wanted
    Last Post: 04-15-20, 09:04 AM
  2. Higher sportbike seat
    By maxim_X in forum General Bike Related
    Last Post: 12-08-11, 08:24 AM
  3. Carb sync in NH needed, please read
    By Engimuneer in forum Bike Maintenance
    Last Post: 07-01-08, 09:37 PM
  4. kz440 Carb Headache! need CARB GURUS!
    By Bandit12k in forum Bike Maintenance
    Last Post: 05-01-08, 12:44 PM
