Results 1 to 14 of 14
1970s Honda CB100 Won't run unless Wide Open
    Lifer snwbrdr435's Avatar
    Middle of Nowhere
    Just got a free CB100, it's sat in an airplane hanger for the last 20 years and has around 5k miles on it. Its gotten a brand new carb put on and still wont idle, starts and runs at wide open fine. Any ideas?
    Re: 1970s Honda CB100 Won't run unless Wide Open
    Jetting miles off, float height miles off, air leak?
    Air leak.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    Middle of Nowhere
    Air leak.
    I was told all the fuel lines have been replaced etc, I'll give it a look over when I go to pull it out of the hanger tomorrow night and let you guys know what I find.
    Points?
    Sep 2005
    Sutton
    First thing is to replace the intake boot from the carb to the engine. You can test this by running the bike and pointing a garden hose of running water at the boot and listening to the engine. If the sound changes it's leaking. A 40 year old piece of rubber is probably spent.
    Is it a brand new carb? If it's a rebuilt be sure to check the jets. If new make sure it came with the same jets as the ones in your original carb. They usually are clearly marked.
    Google around and see if you can find how to video or threads on the subject.
    CB100/CB125 Hybrid aka CB112.5
    Lifer capitalcrew's Avatar
    Feb 2017
    Albany NY
    I would use a bit of starting fluid / ether instead of water personally.
    Middle of Nowhere
    It's a brand new carb, there are also two other brand new ones in boxes. Still have to go grab the thing, but it would be great to rip around before it snows all next week.
    Posting Freak
    Dec 2009
    I’ve always used the gas from an unlighted torch to find vacuum leaks on hoses or cracks in intake manifolds for cars. You slowly move the torch head along side the hoses, fittings and manifold. When the engine rpm changes you’ve likely found a leak. There’s usually more than one. I could see it being a bit trickier with a bike as the air filter intake is quite close. I’d probably try using a small hand held propane torch as the nozzle is pretty small and easy to direct into tight spaces. If using a cutting torch just use the volatile gas, not the oxygen and just a bit is all that's needed.
    I suspect water would work but it might be a bitch if it sucks too much in and stalls.
    Quote Originally Posted by 02redhawk View Post
    Water would be the best method IMO. This is because it has a small molecular size compared to other molecules which would allow it to slip through cracks that might not be detected by larger molecules.
    Just run it pinned all the time
    Does it stay running on starter fluid
    Good point it is a 100. Either totally on the gas or off.
    Actually cool. Loved all those Honda CB and CL and SL in the 70s. So many displacements.
    Mar 2007
    Andover, Ma
    I have built/rebuilt several of these. They are not super complex but need to be set up properly.
    It will need the right fuel mix - if that is a China carb there is suspect #1. Make sure the tank/ fuel tap are clean. Clean and adjust the points - bonus points if you replace them with OEM (see carb reference above). Make sure you have a fresh battery.
    Check also that you have no restrictions in the airbox. In my experience air leaks caused hanging revs and wild idle speeds - check the basics first. My $ is on battery/points.
    Lifer Stromper's Avatar
    Eastern Ct
    Fleabay new carb for $20
    Smear/coat carb boot with black silicone
    Its a 100 should only run wide open
    The calculus of hate
  1. are there any Honda Dealers open on Sundays?
    By scubasteveRR in forum General Bike Related
    Last Post: 11-09-15, 04:29 PM
  2. Wide Open Expo
    By BrianC in forum General Bike Related
    Last Post: 03-05-13, 01:41 PM
  3. Replies: 19
    Last Post: 04-07-11, 10:07 AM
  4. Cafe/modded 1970s CB750 pics?
    By schleppy in forum General Bike Related
    Last Post: 08-24-08, 07:43 PM
  5. Wide Boots
    By goldencoop in forum General Bike Related
    Last Post: 09-21-04, 08:31 PM
