Results 1 to 12 of 12
81 CB750 Not charging
    Posting Freak 6 Fingered Man's Avatar
    Feb 2009
    Exeter NH
    I replaced the reg/rect, batt, stator, brushes, starter solenoid, removed cleaned and redid ground, and Pos connections... WTF any ideas? i cant get it to read over 11.8v
    LRRS #951
    My girlfriend wants to be like me when she grows up.
    Sometimes violence IS the answer. The answer every other time is busa.
    Re: 81 CB750 Not charging
    Whats the resistance across the flywheel?
    Feb 2009
    Exeter NH
    Measured from the brush contact points?
    LRRS #951
    Measure there, and directly on the flywheel itself. I've got to dig to find the numbers but i want to say 4 to 6 ohms is the ballpark you're looking for?
    Feb 2009
    Exeter NH
    Are we going from the inner and outer part of the flywheel? I cant get a ohm reading across it at all. Ill go try again.
    LRRS #951
    Sorry, meant rotor, and between the two slip rings where the brushes contact.
    Feb 2009
    Exeter NH
    I have the two brush contact points, no impedance there. its the same chunk of copper. as far as my ohm meter is telling me its all one big mas of connectivity every where i can measure. I might be misunderstanding you. This shit is out of my comfort level...
    LRRS #951
    I'll see if I can find a pic, but based on what you're saying it sounds like your rotor is toast. No resistance means there is a short, which means that rotor doesn't setup a magnetic field, preventing the stator coil from generating any current.
    http://www.regulatorrectifier.com/ca...es/esf901-.jpg
    See them big, purty copper rings? That's what you need to measure across. You want to see 4 to 5 ohms of resistance. Anything less and that rotor is shot.
    Feb 2009
    Exeter NH
    ohm meter at 200 i have 00.3 reading... shot??
    LRRS #951
    Dead short in there somewheres for sure, thats why you can't coax any charge out of it.
    Feb 2009
    Exeter NH
    Goddam it... So go to the salvage yard with a meter, find one that registers 6 ohm and buy it? WTF is this not in the manual as a possible problem when you get no charge. Damn you josh being smarter than Hayes...
    LRRS #951
  1. For Sale - Motorcycles | CB750 Chop
    By nick5446 in forum For Sale
    Last Post: 03-13-20, 03:21 PM
  2. Wanted - Parts & Tools | Looking for old CB750 parts
    By nick5446 in forum Wanted
    Last Post: 05-26-17, 08:46 AM
  3. Looking for another CB750!
    By 6 Fingered Man in forum For Sale
    Last Post: 07-19-09, 12:44 PM
  4. Pre Reg charging
    By union in forum Pit Area
    Last Post: 04-21-09, 11:26 AM
  5. WTB: CB750
    Last Post: 03-21-09, 10:38 PM
