Results 1 to 19 of 19
adjust clutch
    Member cookie's Avatar
    Jun 2009
    jp
    adjust clutch
    hey guys..anyone know how to adjust a clutch? my lever has way to much play in it.is it something that can be done easily?any pointers would be appreciated. thanks
    Re: adjust clutch
    If it's a cable clutch then there's a thumb adjuster on the lever perch. Adjust so you have about 5mm of play
    If it's a hydraulic system, sometimes there's a bolt and set-screw on the lever near the piston.
    Jun 2009
    jp
    Re: adjust clutch
    i think its a cable? 05 gsxr 1k.
    Re: adjust clutch
    Part 15 in this photo.
    That's the fine cable adjustment. There should also be a coarse adjuster at the other end of the cable where it meets the engine casing.
    I would definitely pick up a service manual if I were you. You can download them off the net in pdf format.
    http://www.scribd.com/doc/284808/Suz...Service-Manual
    Just Registered Omahastylin16's Avatar
    Apr 2008
    Scituate, MA
    Re: adjust clutch
    yup, if its really bad you wanna adjust it on the clutch cover connection, and then fine tune with the knob on the clutch lever
    "Chatbox...It's like Vegas, for your fingers."
    Originally Posted by CBR_Knight
    in my own thread, let me post this:
    first of all, nothing about sex or play with a female seems interesting or arousing to me....
    "BALLS" is coming home late after a night out with the guys smelling of perfume and beer, lipstick on your collar, slapping your wife on the ass and having the balls to say "you're next!"
    Rockin' the West Coast... Femmekat's Avatar
    Jun 2009
    Santa Barbara
    Re: adjust clutch
    And if you adjust both and still too much play, the cable is probably stretched and needs to be replaced...
    I dunno, you dress too fashionably to be a communist
    LRRS Novice #629
    I ride/drive:
    2000 Yamaha R6
    1996 F-350 4x4 diesel truck
    and anything else with serious hp
    Lifer Stromper's Avatar
    Eastern Ct
    Re: adjust clutch
    The adjustment is under the throttle bodies not on the side.
    If the clutch squwaks its normal
    Re: adjust clutch
    I may be wrong, but isn't the clutch adjustment a push rod under the sprocket cover
    adjusters at each end of the cable only adjust the cable, not the clutch
    the primary reason for clutches going bad and cables going bad is people fiddling with the cable thinking they are adjusting the clutch. while you can bring the clutch out of adjustment by fiddling with the cable, you can't adjust it properly unless you first adjust the pushrod
    Re: adjust clutch
    Randy, look at what he's trying to achieve.
    Quote Originally Posted by cookie View Post
    hense, it's probably just a clutch cable that needs adjusting.
    Dave, if you're going to be making a trip up to the track this weekend to spectate, I can take a quick look at it when you're up there and show you how to adjust the cable from either end. I assume Suzuki uses a similar set-up on my SV.
    Jun 2009
    jp
    Re: adjust clutch
    thanks guys..i know its only the cable and not the clutch itself case its catching at the right spot. its just the lever that is loose when you touch it. i think ill wait until i meet up with some of you guys and you can teach me. don't want to make it worse cause i don't know what im doing. maybe meet up on newbury and "pose" one of thses nights and do it there.lol. thanks for that that link for the manual. almost went out and bought one for 60 bucks! appreciate it.
    Re: adjust clutch
    BTW, I dunno HOW loose you're talking, but it should be a *little* loose so that you know there's no more tension on the cable when the lever is fully released.
    Re: adjust clutch
    hey Oreo, wanna grab my lever
    Re: adjust clutch
    er.... I mean
    Jun 2009
    jp
    Re: adjust clutch
    ya. its really loose.lol. i know its not normal
    Re: adjust clutch
    Quote Originally Posted by DBKromz View Post
    Now who's the one not contributing anything useful.
    Re: adjust clutch
    chuck, you wanna pull my lever too?
    Re: adjust clutch
    Alex says yours is more like a light switch.
    Re: adjust clutch
    Paging pigman.
    Eastern Ct
    Re: adjust clutch
    WAy Ghey Hyjack
  1. $$$ carbs cleaned/adjust
    By sluggah in forum General Bike Related
    Last Post: 07-19-10, 09:27 PM
  2. When to Adjust Valves?
    By csmutty in forum Bike Maintenance
    Last Post: 04-11-10, 12:20 AM
  3. Idle speed: how to adjust?
    By chr|s sedition in forum General Bike Related
    Last Post: 08-07-06, 07:40 PM
  4. Valve adjust demo
    Last Post: 05-08-03, 07:30 AM
  5. How do I adjust this?
    By Kham in forum Bike Maintenance
    Last Post: 12-22-02, 07:52 PM
