Hey guys, does anyone with an F4i know how much oil they usually have to put in after an oil and filter change?? The manual says 3.5 ....I got a good drain and then filled her up but the case was over filled???almost every bike mechanic I talked too says to get the level in the window between the lines. I thought the level was supposed to be up to the top line..any way, I put in just over......and i mean barely over 3.5 qrts of oil in and the level after a few hours was high. I asked a bike tech and he looked at it & said it was overfilled. I went out and got something to suck some of the oil out so I didn't have to take out the drain bolt. I took out about 8.5 ounces of oil, roughly a 1/4 of a quart. and now the level is just below the top line when the bike is perfectly level. the slightest change in lean of the bike drastically changes the level in the window. AM I OK??Does this mean my bike only took just under 3 qrts of oil to fill after a good drain???What should I do?? THanks guys.
