Results 1 to 16 of 16
battery question
    Lifer imkindafkedup's Avatar
    Jan 2006
    Saugus, MA
    battery question
    SO i believe I need a battery for the 12r. One problem is starting sometimes sounds like it takes a few more clicks then it use to, second-the lights seem to dim and brighten given the rpm of the motor even when I upshift I notice the headlight dim then brighten, and third -stalling also seems to be occuring when it shouldn't, and no it's not me! Where do you guys get batteries? I was thinking pepboys or walmart.
    Lifer eboos's Avatar
    Re: battery question
    First, do a load test on your battery, then check your grounds. Rule them out first before throwing $80 at it. I found that there is no real money savings by buying a battery at walmart. Try your local dealer, or maybe interstate battery.
    Meriden, Ct
    also check charging output to rule out a stator or rectifier issue.
    Lifer ZX-12R's Avatar
    Candia, NH
    Are you still on your original battery? If so, at 8 years you've already greatly exceeded the life expectancy of it.
    Leo loridin64's Avatar
    Outside Lowell
    +1 on stator and regulator/rectifier.
    a buddy just had them go on his R6 and it was basically the same syptoms that your mentioning. Problem is, there isnt any way to really test a rectifier. You can do an Ohm and resistance test, but its not that conclusive. Also, after the problem happens, touch your rectifier and see if its hot... if so, its overloading and most likely causing your problems
    2002 RC51
    USMC - Semper Fi
    POW/MIA - Not Forgotten
    The Fastest Indian! kamikaze's Avatar
    Jul 2008
    Delhi, Indiaaahh!
    I think my problem is something similar.....
    My bike was parked in a garage for about 10 days in Portsmouth and when I went to get it, the bike started in two tries. However when I got it here, I could not ride it for a while. When I tried to start it after 2-3 days it won't start. Since then it does not start so I have been jump starting it. Once jump started, it runs pretty well. However if I shut off the warm engine and try to start it back again, it does not start. There is a very strong clicking sound everytime I try starting it. Rectifier problem or simply a battery issue?
    Sold: 1999 Kawasaki ZX-7R
    2005 Pulsar 180 DTSi
    Owning: Pulsar 220 DTSi
    http://www.dhairyagupta.com
    http://bostonbiker.blogspot.com
    Old and Slow Sheppo's Avatar
    Westford, Ma
    make sure all your connections are clean and tight.
    Posted by Jane in BoxChat
    Sep 2007
    Middlebury VT
    Remove the battery and check fluid levels.
    I like my battery tender, best $40 I ever spent for the bike's upkeep.
    Jul 2008
    Delhi, Indiaaahh!
    I have checked it. The connections are good
    Quote Originally Posted by Ericthejet View Post
    Its a maintainence free battery. Sealed.
    Westford, Ma
    Quote Originally Posted by kamikaze View Post
    a battery tender keeps the battery charged. Unlike a charger it cycles itself on and off as needed.
    +1 on the Battery Tender
    $40 ? like spending more than double eh? I bought mine for $14.95
    Sep 2007
    Middlebury VT
    So.
    Jul 2008
    Delhi, Indiaaahh!
    So is it a battery problem only? confused now whether to get the battery tender or a new battery or none as I am selling the bike.
    Nov 2004
    Boston, MA
    I imagine you will have better luck selling a bike if it starts.
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Lifer DuncanMoto's Avatar
    I think I need to buy my tenders from you instead of TR. How much for a case?
    Jan 2006
    Saugus, MA
    definitely get a battery tender, it is inevitable that you will be needing it at some point in time. I kept the battery on the battery and reconnected everything. I assume it was just a connection issue and reconnecting everything was what solved the problem.
  1. Yet another battery question
    By Punjistick in forum Bike Maintenance
    Last Post: 08-28-07, 08:08 AM
  2. Battery question
    Last Post: 03-23-07, 09:45 AM
  3. battery question
    Last Post: 03-06-07, 09:05 PM
  4. Battery question
    Last Post: 03-24-06, 10:39 AM
  5. Battery question
    Last Post: 01-11-03, 09:29 PM
