After lending my bike to a friend for a bomo day I was told that my chain was super tight and needed to be adjusted after I know I set the slack properly. I took a look and I found that there are 3 or 4 links that do not sit/fit on the sprocket properly causing the chain to tighten up. I've never seen or heard of this so I'm wondering if it's the chain, sprocket or both?
Wirelessly posted
What he said.
I appreciate it, erv3's aren't cheap so I'd much rather resolve the issue without replacing. Measurement was off a bit but while the axle nut was loose I decided to pull the tire and soak the chain.
Thanks guys
Just sent him a pm, I owe you a beer thank you.
Hey...your chain is toast.
Your chain is jabunk. If it were me i would cut out the bad links and take some out of a spare chain, use two rivet style masters and viola ride!!
Don't forget to tighten you oil drain plug.
Stoopid gingers...
