Results 1 to 5 of 5
Starting a Duc in the cold
    Newbie Deborah's Avatar
    Hi All,
    So I'm relatively new at riding, and I was hoping for a few tips on getting my 696 up and running in the cold/clammy weather.
    On days like today it usually takes me 10-20 tries to get it on and running. It starts, but either won't turn over or will once or twice and then dies. Obviously once the engine turns, I turn the throttle on (I've been told not to turn the throttle on until it's running). But even if I cheat and turn it on before I try and start the bike, it doesn't really seem to help.
    I know it's a Ducati and therefor will be finicky to start, but I was wondering if there were any tips on how to get it up and running a little smoother.
    Thanks,
    Deb
    There is only one thing in life worse than being talked about, and that is not being talked about. - Oscar Wilde
    Re: Starting a Duc in the cold
    A) Keep it on a battery tender when it's parked if you can. Voltage is your friend.
    B) The bike has a stepper motor that raises the throttle automatically when cold... it doesn't always do it enough, so a touch of throttle while cranking can sometimes help. While the bike is initially warming up you may have to hold it's hand by maintaining a touch of throttle as well.
    C) The temps haven't been cold enough for it to have these kinds of starting issues, get it looked at. Ducati's haven't been finicky starters for years.
    Hypertarded
    RI / CT border
    , brand new bike shouldn't have starting issues like that, my Hyper starts 1st push every time never touch the throttle, get it back to the dealer to look at. From the Ducati forums it seems as if there were issues with some people having constant starting/stalling issues while others with the same model had none, ECU replacement, throttle body synching, bleed screw setting seemed to be the usual culprits. Good luck
    P.S: I did need to get my ECU replaced last year, bike just would not start at all got a "stepper motor error" on the screen, no issues since.
    .... naked-daytrader's Avatar
    May 2007
    Quote Originally Posted by Deborah View Post
    Hi All,
    Thanks,
    Deb
    Talk to it....always worked for me.
    CCS|LRRS EX#49
    2006 KTM 560 SMR - 2006 Yamaha R6
    LRRS Rookie of the Year 2002-2006
    Thanks guys!!!
    Even you Mr. Daytrader...at least I got a good laugh out of your bright idea!
  1. sticky throttle/prolonged revving when cold starting? (2009 R1)
    By *GhostRide37 in forum Bike Maintenance
    Last Post: 10-27-13, 11:26 PM
  2. Cold tires and cold road
    By netra709 in forum General Bike Related
    Last Post: 11-22-08, 10:51 AM
  3. When is this starting again?
    By HBerry in forum Motorcycle Night - Lowell
    Last Post: 05-07-05, 07:20 AM
  4. TDM-850; One Cylinder Dead When Cold-Starting
    Last Post: 07-31-02, 10:31 PM
